fan problem
Old Aug 10, 2016 | 02:47 PM
brinny's Avatar
Default fan problem
my 4 .0 coupe on heavy acceleration causes the radiator fan to catch the cowling. there is also a smell that at first made me think the clutch in the gearbox was going. its a manual. any suggestions lads? ive renewed the gearbox mount which helped a little but its still catching the surround when you give it some? thanks
Old Aug 10, 2016 | 05:00 PM
orangeblossom's Avatar
Hi Brinny
I would stop driving the Car right now until you've managed to sort the problem out, because if one of those Fan Blades snaps which it is quite likely to do if it's catching the Cowel.
It could cause the Fan to break up and not only take out your Rad but also put a big dent in your Bonnet/Hood.
Old Aug 10, 2016 | 05:43 PM
baxtor's Avatar
How are your other engine mounts?
Old Aug 10, 2016 | 06:46 PM
Jagboi64's Avatar
Also look at the surround itself. On the earlier saloons it was held at the bottom with part of the sheet metal bent into tabs. If that's rusted the shroud itself can sag and catch the fan.
On heavy acceleration the right side of the engine will lift, make sure that engine mount is sound and the rubber has not come apart and isn't holding the engine down.
NoHub55
Apr 29, 2016 10:59 PM
Edelweiss
Apr 26, 2016 07:51 AM
adenshillito
Apr 19, 2016 05:22 AM
trucknetjack
Mar 31, 2016 04:12 PM
IronCobra
Feb 11, 2007 12:01 AM
