Front axle nut torque?
It's not torqued. You tighten the nut just enough, just beyond hand tight, to take up all float in the bearings, then back it off slightly to allow .002 to .005" end float. Then put the nut retainer and cotter pin on.
Well that sounds scary. So the cotter pin is the only thing securing the nut? And the nut is the only thing holding the hub and disc in place? I guess the caliper helps too, but still…my MR2 axle nut took something like 140 ft-lb. Hand tight doesn’t inspire confidence.
The worst thing you can do with the XJS front wheel bearings is overtighten them and then run them that way. As the hubs warm up clearances are reduced.
The sealed bearings you are used to are built as a unit, with clearances determined by manufacturing tolerances and the preload. The XJS bearings are independent of each other, and are adjusted in a different manner.
If you have not done this before, then this is what works for me:
- do up the nut until there is definitely NO end float - not stupid tight, but definitely no float
- you will then find you can turn the hub but definitely feel it is resisting, with a slight binding feel
- turn the nut back about 10 minutes on the clock (ie 30 degrees or so)
- then try turning the hub and if still a bit of resistance, undo five minutes more
- if loose do it up a touch
- you will get the hub to the position where you can feel it is turning nicely but not loose (loose meaning you can grasp the disc and move the hub in and out a touch) and not at all binding. That's where you want to be. Sounds a bit worrying, but when you do it in practice you will find the right point is quite easy to locate.
