Front Hub Spindle
Short question. Seems like I have some problems with my left side front Hub Spindle and I might have to replace it. Will a front Hub Spindle from a 1985 fit my 1990 XJ-S.
Regards,
Rune
1990 XJ-S HE V12
Regards,
Rune
1990 XJ-S HE V12
I got both of mine out with a bloody big hammer. Both axles were stuffed and needed replacing so I wasn't worried about damaging them. Remove the carrier and put it in a vice with the jaws loose and a bit of hard wood with a hole big enough for the stub axle to go through. Undo the nut a couple of mm and hit it hard. A few good hits and it came loose.
It might just be easier to get the whole knuckle plus spindle for an abs equipped car (89+), as you would just upbolt everything off and then remove the hub. Sounds like a lot less work, except getting the abs equipped knuckle.
Yes it will fit. Check the axle for wear and make sure the bearings are a snug fit
innzane
Sep 2, 2015 10:08 AM
