fuel filler install?
Old May 21, 2014 | 07:53 AM
ukester's Avatar
Default fuel filler install?
just reinstalled the gas tank and now having a very very difficult time installing the fuel cap-any ideas?
Thanks Mark
Old May 21, 2014 | 08:53 AM
sidescrollin's Avatar
what problem are you having? I just did this last week and had no problems.
After pushing the tank all the way back i put the rubber hose in place with its respective clamps, put the rubber surround over the filler neck, opened the fuel door and pushed the filler down into place.
It takes a bit of convincing because there is a rubber ring in the fuel tank it seals with. After that, spin it about to line the holes up and make sure the leg sticking off the filler neck is towards the back of the car.
also make sure the hose is sitting properly on the tank and filler neck, if the hose is too low (there should be a wear line) then the hose clamp with taper and walk off
dsnyder586
Dec 29, 2024 07:39 PM
1100me
Jul 24, 2023 06:10 PM
kelliott
May 31, 2022 05:26 PM
deanh
Sep 6, 2015 08:20 PM
AL NZ
Sep 4, 2015 08:39 PM
