??? Fuel Interface Unit ??? Where?
Old Aug 14, 2019 | 02:47 PM
JayJagJay's Avatar
Default ??? Fuel Interface Unit ??? Where?
1990 XJS Convertible...
Does anyone know where I can find the "Fuel Interface Unit"?
Old Aug 15, 2019 | 02:37 AM
baxtor's Avatar
As far as l recall it is up with fuel pump relay, front right hand corner of trunk/boot above battery.
Old Aug 15, 2019 | 07:40 AM
JayJagJay's Avatar
Thank you baxtor... Got ya...
It's the million little things that keeps this interesting. By the end,,, or sooner,,, I think I will have had to look for every bit and piece on this doggone machine! Haha...
In this case, it's about chasing down wiring for the components involved with the speedO...
Much appreciated!
Old Aug 15, 2019 | 03:22 PM
Ezrider's Avatar
if your talking about the intertia switch that is supposed to shut off the fuel pump in a wreck its near the pasenger side kick panel. kinda along the edge of the door if i remember right.
Old Aug 15, 2019 | 03:47 PM
baxtor's Avatar
Much appreciated!
Since you mention "speed" l think the speed interface (as opposed to fuel) is over the other side of the trunk tucked up out of the way.
Old Aug 15, 2019 | 03:53 PM
motorcarman's Avatar
I believe Jaguar refers to it as the 'anti-slosh' module.
bob
Old Aug 15, 2019 | 04:19 PM
Doug's Avatar
it'll look like this
I don't think the fuel interface unit has any bearing on the speedometer. The speed interface unit, as already mentioned, does, though.
The fuel interface take injector pulse measurements and converts them into something the trip computer can understand to compute fuel economy
Old Aug 15, 2019 | 04:24 PM
JayJagJay's Avatar
Got it. And thank you all!
Crazy thing is,,, I've seen the thing 1000 times.
Getting closer. Stoked.
Had to partly rebuild the shelf and cabinet... Still have some trimming and tucking to do!
Old Aug 15, 2019 | 04:32 PM
JayJagJay's Avatar
it'll look like this I don't think the fuel interface unit has any bearing on the speedometer. The speed interface unit, as already mentioned, does, though.
Thanks Doug... I started chasing this due to it's mention in the diagram below. Just wanting to make sure bout as much as possible. The damn speedO thing that I (for the life of me) have not been able to get close to right. Thinking to rewire all things (within reason) connected to it since I have the insides so opened up.
I have:
3 dash speedO dials
1 new sender at the diff
And a while back - a "new" interface.
Something has to give!
The GREEN wire goes to many things,,, right up to the back of the dial in the dash... The chase
THIS IS THE "CP7" connector/plug in the diagram. That splice is the shielded white wire that begins at the diff,,, thru the interface,,, into the car. Then all colors change and wires start going to the different components.
Old Aug 15, 2019 | 05:19 PM
baxtor's Avatar
I have:
3 dash speedO dials
Jay, l assume the "new" interface unit you mention in your list was a speed interface and not the fuel unit.
Old Aug 15, 2019 | 06:41 PM
JayJagJay's Avatar
Yes baxtor... My bad. The interface for the speedO on the LH side area of the boot.
scottpeterd
Jan 10, 2026 04:47 PM
annamiata
Jun 18, 2023 10:47 AM
Anchor2
Jan 21, 2017 04:42 PM
hondakillah
Apr 28, 2015 08:18 AM
woodpuppy
XJ40 ( XJ81 )
36
Apr 17, 2009 02:27 AM
