Fuel Line repair
Old May 29, 2018 | 06:49 PM
Fla Steve's Avatar
Default Fuel Line repair
Is there a Thread on how to repair the crimped end type hose that runs from the B bank Pres regulator to the Refrigerant cooler? Is there a nipple that protrudes from the crimp bezel enough to fit a small hose clamp? Or is there a more professional way to do it??? Do you have to cut off the crimp bezel?
Attached Thumbnails Fuel Line repair-dsc04211.jpg   Fuel Line repair-dsc04212.jpg
Old May 29, 2018 | 10:35 PM
Doug's Avatar
Lots of threads about fuel pipes and hoses. Here's one
https://www.jaguarforums.com/forum/x...atives-201065/
What you're thinking is a crimped fitting, isn't. The hose presses onto barbed nipple. What you're thinking is a crimp fitting is a ferrule...a cap-like widget that Keeps the end of the hoses intact. Lots of shapes and styles out there. I use the same type as seen on the fuel injector hoses, part EAC7876, available from various Jag suppliers, but others have their own preferences
*Carefully* cut the ferrule and hose off the nipple....you don't want to damage the nipple...then slip a new ferrule over the nipple then press on the new hose. Done.
Others melt the hose away so the ferrule can be reused
Attached Thumbnails Fuel Line repair-eac-7876-k.jpg-ferrule.jpg   Fuel Line repair-fuel-pipe-4.jpg
Old May 30, 2018 | 04:41 PM
sidescrollin's Avatar
Apparently you can just cut it apart. I had a local hydraulic shop remake it reusing he hard bit for about $20.
wrestling it out around the inlet manifold is kind of a bear.
bluerdg
Jul 7, 2023 12:12 AM
afterburner1
Aug 18, 2017 04:32 PM
Jagxjs
General Tech Help
Dec 17, 2012 05:06 AM
Charles
Nov 1, 2012 07:36 PM
thuffner3
May 26, 2011 12:34 AM
