Fuel pipe flat
Old Dec 27, 2018 | 12:51 AM
brinny's Avatar
Default Fuel pipe flat
Hi all, I’ve noticed a bit of a flat spot on my fuel pipe supply. I must have done it when I pushed it through the firewall. As I say it’s on the supply side. Question is will it need cutting out or is there enough pressure that it won’t matter? Thanks
Old Dec 27, 2018 | 02:06 AM
user 652867429824's Avatar
I don't think it would hurt, but a picture of it may help in determining. Also, maybe someone with a bit more knowledge than mine will chime in soon
Old Dec 27, 2018 | 02:39 AM
Greg in France's Avatar
Brinny
Either post a photo, or do a flow test by hotwiring the pump and seeing what volume comes out of the supply in 2 minutes, say, and ten calculating the volume per hour or whatever. Basically, extra joins are not a good idea in a hard line IMO, as vibration/knock etc etc will, at some point, loosen them.
Greg
Old Dec 27, 2018 | 02:47 AM
brinny's Avatar
Thanks. I will get a picture.
ln69bt
46
May 26, 2018 01:39 PM
Northern XF
Jul 30, 2017 09:03 AM
Evan Trinh
Feb 25, 2016 06:04 AM
vincent661983
Jan 31, 2013 08:01 AM
plums
Jan 3, 2012 02:57 PM
