Fuel Pump Relay
Old Aug 31, 2015 | 02:38 AM
BigD's Avatar
Default Fuel Pump Relay
Hi, I have an early (75) v12. According to a wiring diagram I have the fuel pump relay is 'hot' as in constant 12volts supplied, regardless of ignition switch position. Would this be correct?
Thanks.
Old Aug 31, 2015 | 04:20 AM
Sort of.
Depends as to whether its a "Fuel Infected" engine or a "Carby model".
For the Infected:
The Brown heavy wire is 12v HOT, then the ignition switches the relay ON, and then the other 2 wires are the PUMP, and EARTH. Earth is via the ECU, and its timer feature.
For the Carby:
Same deal, except the Earth is via a reverse oil switch, I THINK, as it has been a very long time.
Old Aug 31, 2015 | 06:13 AM
BigD's Avatar
Fuel infected. That makes sense. Ta very much.
dsnyder586
Dec 29, 2024 07:39 PM
Sprayall
May 30, 2021 08:13 AM
ccfulton
Sep 20, 2015 05:15 PM
Kmw
Sep 8, 2015 04:52 PM
Sprayall
Sep 3, 2015 07:49 PM
