Full Throttle and KickDown Switches 2 vs 3 leads???
Old May 20, 2017 | 02:56 PM
Dania Bar's Avatar
Default Full Throttle and KickDown Switches 2 vs 3 leads???
Guys I am not sure what to do here. Maybe I am just new to this. I am replacing both the Full throttle and Kick Down microswitches. the originals have 2 leads coming out of them and I have two wires for each. But the new switches have 3 leads coming out of them. Did I get the wrong switch and if not which one is extra? The car is a 1988 XJS H&E. Attached is the pic of original and new one.
Thanks for the help
Attached Thumbnails Full Throttle and KickDown Switches 2 vs 3 leads???-original.jpg   Full Throttle and KickDown Switches 2 vs 3 leads???-new.jpg
Old May 20, 2017 | 03:12 PM
Doug's Avatar
It is very common for replacement switches to have the extra terminal....thus making them suitable for a greater variety of purposes.
The terminals are probably marked NO, NC, and COM (normally open, normally closed, and common)
For the two applications you have in mind attach one wire to "COM" and the other to "NO".
Old May 21, 2017 | 01:57 AM
Greg in France's Avatar
Where did you get that STDP (three terminal) switch from please? They are needed for the handbrake warning light circuit, and are unavailable from the usual specialist suppliers
Old May 21, 2017 | 03:08 AM
baxtor's Avatar
Greg, many years ago when l was running 4 speed O/D box in my series 1 xj12 l wired the overdrive through the kickdown switch by changing it from NO to NC. The stock kickdown switch has the provision for the change by removing a small blanking piece and moving the spade blade from NO position to NC position. As l remember the rivets need to be removed to split the switch.
Having said all that they are a very common microswitch.
Old May 21, 2017 | 03:25 AM
Thanks Baxtor. The handbrake needs a three terminal jobby, I am glad I shall be able to get one OK.
Old May 21, 2017 | 07:57 AM
Doug's Avatar
Mouser has hundreds of 'em
http://www.mouser.com/Electromechani...tches/_/N-5g2v
A quick perusing revealed this....which might fill the bill. But I'm on my first cup of coffee and still a bit blurry-eyed
http://www.mouser.com/ProductDetail/...ZEL2zpWZOh0%3d
RagTopJag
Jun 15, 2021 08:38 AM
Doug
Apr 22, 2021 06:08 PM
Doug
Feb 20, 2021 03:32 PM
Simm
Mar 2, 2020 03:56 AM
bullittandy
Sep 8, 2016 02:31 PM
