Which fuse for opticell? (1989 XJS, UK RHD)
Old Jul 12, 2025 | 01:39 PM
mattsquire's Avatar
Default Which fuse for opticell? (1989 XJS, UK RHD)
Hello, I've spent 2 hours researching this and can't find the answer. When changing the opticell today (1989 XJS 3.6, UK RHD), I think I may have blown the fuse. I think I've blown it because the new opticell was working then stopped when I was fiddling around with the wires, with the ignition on. Can someone tell me which fuse the opticell runs off please, so I can check it?
Old Jul 12, 2025 | 02:22 PM
Greg in France's Avatar
In a V12 it is the same fuse as for the panel lights, fuse number 7 (counting from the left) in the main fuse box under the steering wheel on the shin trim; I think the 3.6 will be the same. It also controls the cigar lighter. The fuse box cover should have the fuse numbers and circuit identification on a label on the inside.
It is quite fequent now that the copper clips that hold the fuses give up their spring-ness or get slightly corrded and will not conduct. So worth checking that aspect.
Old Jul 13, 2025 | 09:34 AM
mattsquire's Avatar
Thanks Greg.
i8thesandbox
Jul 29, 2024 06:00 PM
tylerbowe
Oct 18, 2017 01:04 AM
luds1
May 8, 2014 11:53 AM
Kain
Sep 16, 2008 07:50 AM
