Gas Cap Key for XJS
Old Oct 3, 2021 | 10:19 PM
Pendax7's Avatar
Default Gas Cap Key for XJS
When I got my XJS, the gas cap didn't have a key so I'm driving around with it unlocked.
How do I fix a replacement part number so that I can replace it with a working key.
It looks like i can run down to the auto part store and get a replacement thing that looks like a cylinder.
Old Oct 4, 2021 | 01:24 AM
ptjs1's Avatar
You can find your key numbers from Jaguar Heritage and then just a new key cut.
Good luck
Paul
Old Oct 4, 2021 | 09:13 PM
Pendax7's Avatar
Would you provide the weblink to the Jaguar Heritage. I had googled it but there is nothing on getting a key or even parts, just a certificate.
Old Oct 5, 2021 | 07:43 AM
malc4d's Avatar
The key numbers will be on that certificate. Also as a long shot, did you get the original keys with a plastic band that has numbers on it ?
Genuine Jaguar Key blank for 1981 - 1987 XJ6 & XJ12 doors - BL6 | eBay
This should fit if you can get a locksmith to cut it to your lock
Old Oct 5, 2021 | 07:56 AM
ptjs1's Avatar
Jaguar Heritage used to run the key replacement service for the classic models. Not sure if they still do it, but they definitely have access to the key numbers in the build records for your car. Even if you're not ordering a Heritage certificate (which you should buy anyway!), if you can show proof of ownership of the car to them, they should be able to provide you with key numbers.
Paul
Old Oct 5, 2021 | 08:11 AM
Pendax7's Avatar
I didn't get a key when i got the car.
I did however purchased a blank Jag key so that i can get it keyed correctly.
Thank you for the info.
fishbait1
Aug 10, 2020 09:58 AM
Paul Mackay
Jul 12, 2018 09:54 AM
Stogie
May 30, 2013 02:01 PM
MRomanik
Sep 9, 2012 06:10 PM
