gas cap key
Old Aug 9, 2020 | 10:41 PM
fishbait1's Avatar
Default gas cap key
i don't have a key to lock the gas cap door. is this something a locksmith could make if i had a blank?
thanks
Old Aug 9, 2020 | 11:30 PM
VancouverXJ6's Avatar
It should be the same as your door key.
Old Aug 10, 2020 | 12:34 AM
ptjs1's Avatar
It depends on the year of your car (at least for UK models it does)
On late facelift cars, the petrol cap key is completely separate from the other keys.
Jaguar Heritage keep records of all the original key numbers for your car, if that helps.
Good luck
Paul
Old Aug 10, 2020 | 08:35 AM
malc4d's Avatar
On the first of the facelift cars the door key is also the fuel cap key, but if you have the tibbe door key you will need to get a key made.
Old Aug 10, 2020 | 09:44 AM
fishbait1's Avatar
my car is a 1994 so it has the strange looking key, tibbe key? i'll check with the local locksmith. they had a code for my 60 Impala. they might have one for the Jag.
Old Aug 10, 2020 | 09:58 AM
ptjs1's Avatar
If you've got a Tibbes door and ignition key, sadly, I would be amazed if your local locksmith has a code for the separate fuel cap flat blade key. Even Jaguar dealers can't access the build key codes. Only Jaguar Heritage have access to those records.
Good luck with getting it sorted.
Paul
dsd
Apr 2, 2019 07:51 PM
salukutinaveen
Oct 22, 2017 10:16 PM
BCJAG
XF (X260)
Oct 20, 2016 10:49 AM
Stogie
May 30, 2013 02:01 PM
vaccaro81
Mar 8, 2007 02:32 PM
