Gas smell when driving
Old Jun 7, 2017 | 07:14 PM
dtony's Avatar
Default Gas smell when driving
Hi all,
I have a 94 XJS Convertible 6cyl. I recently replaced the fuel pump and filter. Got everything back together and when I drive I get a slight smell of gas. When parked and the hot up, I can't locate the smell or the source. It also seems to be strong in the trunk as well, but again I seen nothing that indicates a leak anywhere.
Any ideas you can offer are much appreciated.
Tony in NM
Old Jun 9, 2017 | 05:42 PM
ronbros's Avatar
dtony, a very common complaint ,,fuel smell in Jag trunk,mine included!
maybe some small road vent when driving, or there abouts!
mine after a drive seems ok, but overnight it returns the next day!
annoying yes, dangerous no.
Old Jun 15, 2017 | 11:17 AM
dtony's Avatar
I don't get any smell when it is sitting or idling. It seems to show up during a drive and particularly during an acceleration. I don't see any leaks or anything spraying beneath the hood or trunk.
Tony
Old Jun 15, 2017 | 04:33 PM
sidescrollin's Avatar
Recently replaced fuel stuff? Are you sure it isn't just smell from fuel spilled in that process?
Old Jun 16, 2017 | 01:15 AM
Greg in France's Avatar
Tony
I am sorry to say you most probably have a leak as a result of your changing the pump. Put a bit of talcum powder over the hoes/joins etc, and then take a look at it after a drive.
Greg
Old Jun 16, 2017 | 09:38 AM
dtony's Avatar
What will I see after the drive? Should I look under the hood as well?
Thanks,
Tony
Old Jun 16, 2017 | 11:16 AM
Unless you changed anything under the hood, I do not think you need to do anything there. The TP should show signs of runs if there is a leak.
Greg
