Gasket sealer
Old Jun 17, 2021 | 03:34 PM
garethashenden's Avatar
Default Gasket sealer
I'm about ready to put my cooling system back together. I feel that it would be a good idea to use some sort of sealant on the paper gaskets, such as the waterpump, but I'm not sure if A) That's a good idea, or B)What to use.
Your thoughts?
Old Jun 17, 2021 | 03:57 PM
JayJagJay's Avatar
Your thoughts?
Waaaaay back in my earliest days of working on my XJS (lol, bout 3 and ah 1/2 yes ago now) replacing the water pump was one of my first jobs. Thanks Grant and Greg... Honestly, some of my first attempts at car work. Anywhooo...
My late Papa used to use this stuff and when I saw it in the shelf I grabbed a bottle and used it. This, after 2 failed attempts, getting everything back together and starting her up just to find leaks, I used the Indian head sealer and it worked like a charm. It's tough and messy stuff. Gets all over, but I like it for certain things
Just say'n...
Old Jun 17, 2021 | 04:55 PM
Thorsen's Avatar
I'm a big fan of this for cooling systems. A light smear is all you need.
And not trying to start a holy war, but I stopped using the paper gaskets years ago.
Old Jun 17, 2021 | 10:13 PM
Same as Thorsen.
A light smear as a dressing on any gasket.
On its own if no gasket is the flavour of the moment.
I found Grey Hi-Temp by JB Weld, less noticed after the task.
MAIN thing with that water pump is the face of the timing cover MUST be CLEAN, and NO nicks or scratches. If there are nicks and scratches, a little heavier "smear" in that area, fit the pump, let it set for 24 hours, jobs done.
Old Jun 18, 2021 | 01:05 AM
Greg in France's Avatar
I am a great believer in this stuff, put on BOTH the metal surfaces, then place the gasket, then offer up the pump:
https://www.gasgacinch.com/
Old Jun 18, 2021 | 07:48 AM
Doug's Avatar
This is like engine oil and beer. Everybody has their favorites.
I'm a real stick-in-the-mud. I've been using old fashioned Permatex #2 for ages and refuse to try anything else! I'm not saying it's the best. I'm just saying it always works well for me.
Old Jun 18, 2021 | 08:06 AM
Vee's Avatar
Vee
Best logo, for sure!
UalCapt
XK120 XK140 XK150
Feb 5, 2020 04:38 PM
XJ6Paul
Jun 4, 2019 01:23 PM
OUScooby
Aug 22, 2018 06:11 AM
brinny
Sep 6, 2017 01:38 PM
Vee
May 22, 2017 10:13 AM
