Getting closer! good news and bad news
Old Nov 23, 2015 | 01:03 PM
H&Kjaguar's Avatar
Default Getting closer! good news and bad news
Ok so the journey continues with my new Jag...
The mechanic is giving it a complete going over. So far just about all good news...I am replacing all the drive belts, fluids, compression check was excellent, it runs super smooth...I was fearful the radiator might have a slight leak...nope...tight...BUT he has located a leak in the water-pump so I need a new one as I want the cooling system to 100% perfect if not better
The pump isn't too much but I hear its about 5 hours labor? joy
Brakes look good (thank goodness the rear brakes were just recently done as it sounds like that is a joy!) and everything else seems to check out real tight. SO just waiting on WP and install...getting tags and hopfully couple weeks into Dec I will be reporting my first road test drive !!
Old Nov 23, 2015 | 04:00 PM
Jonathan-W's Avatar
Super!
Old Nov 24, 2015 | 06:45 PM
warrjon's Avatar
Changing the waterpump can be a PITA, there is a very large countersunk pozzi screw that in my case required an impact driver to remove.
n8ertot
Nov 25, 2025 09:44 AM
skadmiri1
Oct 25, 2015 01:06 PM
TomFType
Oct 21, 2015 12:06 PM
luds1
Oct 20, 2015 09:53 AM
rttug
Oct 19, 2015 07:11 AM
