Getting shifty with an XJS....
Old Feb 13, 2021 | 11:47 AM
JaguarSpecialties's Avatar
Former Sponsor
Default Getting shifty with an XJS....
Hello all, this is Andrew from Jaguar Specialties
Upfront clarification- I am posting this purely as a technical topic, hopefully interesting to XJS enthusiasts in general, and not as a commercial solicitation of any sort. As a sponsor of the XJS forum I understand the difference.....
Historically Jaguar conversions have been 99.5% automatic transmission equipped. But lately, more and more of our customers are looking to shift themselves, and in most cases they are looking to the GM LS engines with matching T56 (6 speed manual) transmissions. Our kits have always supported manual transmissions but getting the correct pedal box was up to the customer. There were a few providers out there for these parts, but with our knowledge, I recently wondered why not become a supplier as well. Anyone going manual trans on their GM conversion, or even manual trans behind a Jag engine, could use these.....
So over the last few months, we have tooled up to manufacture drop-in, ready-to-roll, manual trans pedal boxes for XJS cars (76-94) and we'll be up to speed on the XJ6 versions (70-87) shortly. (Note- we already offered manual trans pedal boxes for 98-03 XJ8 and 97-02 XK8 models, so these just add to the line)
The first few sets of XJS units are now done and came out very well. The all utilize a fully aluminum welded pedal casting (not bolted together), new clutch pedal, revised brake pedal, and a new Wilwood compact master cylinder. These are very similar to the factory parts (long out of production), and mount to the cars with no modifications or adjustments needed. A standard brake booster (76-88 cars) or brake actuator (89-94 models) bolts right on and they drop right into the car. One important note- the clutch pedals on these units have the correct shape so no cutting of the inner dash structure is required (unlike some of the other "retrofit" units out there). Do you recognize the OE Jaguar style pedal pads there???
I've attached some pics below for you have a look, including showing the units installed in an actual XJS car, as well as how the pedals fall in the footwell. The Wilwood master cylinder is nice as it uses a remote reservoir which can be placed conveniently nearby. Due to the standard mounting pattern, even smaller (overall size, not bore) master cylinders like those from Tilton could be used as well. If you have any questions, let me know.
Andrew
Jaguar Specialties
Old Feb 13, 2021 | 01:03 PM
garethashenden's Avatar
Is there a price?
Old Feb 14, 2021 | 08:08 AM
Mkii250's Avatar
And after the XJ6...maybe X300? Or is that greedy.
Old Feb 14, 2021 | 08:11 PM
Former Sponsor
Default Manual pedal boxes
So to answer a couple of questions:
XJS units- these sell for $695 exchange (customer to trade in his original automatic pedal box)
X300- We have these available as well- they are $525 exchange
Let me know if there are other questions
Andrew
Jaguar Specialties
Old Feb 16, 2021 | 06:28 PM
VancouverXJ6's Avatar
Andrew
Jaguar Specialties
If I got you this This could you fit a modern automatic transmission to my car? I don't see why it wouldn't be possible with a custom made adapter, mounts etc.
Old Feb 16, 2021 | 10:48 PM
Former Sponsor
Default Clarification....
I'm not sure I understand the question correctly, but if you are asking if these pieces would be of any help swapping in a modern automatic behind the V12, the answer is no. These pedal sets are just for manual transmission installations, whether it be behind a V12 or a V8 conversion.
This post is about pedals only
Did I misunderstand your question???
Andrew
Jaguar Specialties
Old Feb 17, 2021 | 12:48 AM
Andrew
Jaguar Specialties
I hijacked the topic sorry, I ment I was inquirering about fitting modern transmissions to the car. We can start a new thread I guess so as not to derail this (manual trans) discussion.
Old Feb 17, 2021 | 08:21 AM
Mkii250's Avatar
Andrew, I looked (and bookmarked) your site but didn't see a link for the X300 XJR 1995-7. I don't know if it would use the same pedal box as the XJ40 or X308, however my question is, would I have to find my own clutch pedal, shifter etc or do you have those bits?
Thanks.
Old Feb 17, 2021 | 08:29 PM
Former Sponsor
Default X300 Pedal Box
Actually, there is virtually nothing on our website for the 95-97 (X300) cars because there is virtually no call for conversions on them- they're too reliable.
That's not to say we don't have a manual pedal box for them, and if that's what you want, we can help, You would get a ready to drop in 3 pedal unit, set up for a hydraulic clutch master. AS far as shifter, that's part of the transmission you would be using, whatever that is... It is neither an XJ40 nor X308 pedal box (completely different and non-compatible with the X300)
I hope that helps
Andrew
Jaguar Specialties
Thanks.
X300 Pdeal bio
Old Feb 18, 2021 | 12:29 PM
Mkii250's Avatar
Ya great thanks Andrew! Prolly put in a Getrag 290 or variant if I can find one. The conversion idea is new but I'm keen and have the time etc. and would appreciate your help. I'm not at all fan of the 4-speed autobox that's in it. It doesn't change quickly enough when you shift manually.
Old Feb 18, 2021 | 10:44 PM
Former Sponsor
Default Any time........
Get back with me whenever you like. I actually have one of the pedal boxes in stock...
icsamerica
Sep 24, 2017 06:48 AM
M90power
Oct 19, 2014 05:56 PM
Mish_Mish
Jun 24, 2014 09:32 AM
Burgurboy
May 19, 2012 06:12 PM
Death Kitten
Apr 13, 2012 10:28 PM
