hard starting
My 87 V12 had been sitting for a while. However she started up with out much coaxing last summer and ran good. I parked the car over the winter intending to start her periodcially. It was at that point she started giving me fits. We can get her started on Starting Fluid and can her to stay running but she will not start on her own. Any suggestions?
PS...she is getting plenty of gas at the fuel rail, the pump is working, she has gas in the tank and it's fresh. Plugs have less than 100 miles on them, new 8mm wires. .
I would grab an old spark plug, insert it in the business end of any easy to access lead, and earth said plug anywhere it lands.
Crank the beast, looking for a FAT Blue CRACK of a spark. No got that?, No start V12.
If that spark sucks, remove the COIL HT lead from the cap, insert that sparker in the end of that lead, and try again.
The other culprits are varied, but not going there until you come back.
looking like it may be the fuel pressure regulator. Put some liquid wrench on the fuel line nuts. Once those are off I can test it. If that's not it I'll just keep working my my way back. We did confirm it is not getting fuel at the rail now but it was getting fuel last week.
looking like it may be the fuel pressure regulator. have liquid wrench on the fuel line nuts now. Once those are off I can Test it. If that's not it I'll just keep working my way back. We did confirm it is not getting fuel at the rail but it was getting fuel last week.
Hi Brad
It could be a Blocked Fuel Filter
Could be as Simple as that, preventing the Fuel from Flowing, even if the Pump is running, as that only runs for 3 Seconds at every on/off turn of the Key actuation
wardriver64
Apr 10, 2014 09:37 PM
