Have a wiring question. AB14 a Amp
Old Jul 7, 2015 | 07:32 PM
Ratfink's Avatar
Default Have a wiring question with the AB14 Amp
I'm re wiring the 88 xjs and I have several wires I'm not sure where they go. I have solid green, green w/white? line, smaller solid white, two white w/ blue line, and a larger gauge solid white. I'm assuming <br/>1) the larger white goes to the coils<br/>2) one of the white/blue goes to the AB14<br/>Because it's a circle connector and that's the only one I can see. <br/><br/>Does the greens go to the AB14 box?<br/>Does the smaller white go to the white/blue that is coming out of the AB14 box?
Old Jul 8, 2015 | 05:31 AM
user 652867429824's Avatar
i belive the green ones are what goes here, since I am redoing mine also, I will look for the other since I have lots and lots of pictures. I may have other pictures that will show them in my photo albums here
Old Jul 8, 2015 | 05:40 AM
Hopr this helps, I believe two connect to the ICU, hope you can see the wires will look for a better pic
Old Jul 8, 2015 | 08:39 AM
reichstall's Avatar
yep got it right
Old Jul 9, 2015 | 06:16 PM
Ratfink's Avatar
Where does the blue and red
wires for the side of the Ab14 come from? I can't find my plug or the wires. I may have to make a new set. Thanks for the help.
Old Jul 9, 2015 | 06:42 PM
moff1959's Avatar
The trigger wiring from the distributor
Old Jul 9, 2015 | 06:46 PM
Safari's Avatar
I'm pretty sure those wires come from the distributor. There is a short harness that connects to the amp. It can be a bit buried so you may have to dig for it.
Mark
Old Jul 9, 2015 | 07:24 PM
Jagboi64's Avatar
If you open up the AB14 box you will see a GM hei ignition module. Here is the wiring for it: http://www.jagweb.com/aj6eng/ce_connections.jpg
The W and G terminals go to the pickup in the distributor. If I recall correctly, the G and B spade terminals are smaller than the other two so they can't get mixed up.
Old Jul 9, 2015 | 10:55 PM
Ratfink's Avatar
Ok... I see said the blind man... I'm missing that wire, I have the plug from the distributor that goes nowhere. I'll have to see if that wire is in my trunk or I'll just have to make a new one. THANKS again!!! Just when I think I'm in over my head yall pick me up. I know I can get this old girl running again.
Old Jul 10, 2015 | 04:30 PM
moff1959's Avatar
Here is some more info
Old Jul 10, 2015 | 06:08 PM
reichstall's Avatar
where you get that print it looks like a blue print for design
Rivguy
Nov 13, 2022 02:55 AM
2001 White XJ8
Feb 25, 2021 05:02 PM
mbergen
Oct 23, 2019 10:26 PM
R-Sport
Sep 18, 2015 01:44 PM
tvholden
Sep 12, 2015 11:13 AM
