Headlight replacement on 1995 xjs
Old Jan 6, 2019 | 07:41 AM
TomR166's Avatar
Default Headlight replacement on 1995 xjs
Having trouble getting bulb mount to release on the single upgrade headlight. Is there a trick to get it to turn to release?
Old Jan 7, 2019 | 07:02 AM
malc4d's Avatar
Remove the plastic access panel in front of the front wheel (not the whole splashguard). You'll then see the headlamp connector. Squeaze and lift off the locking wire and the bulb (H4) will come out
Old Oct 8, 2019 | 09:04 AM
David32407's Avatar
Hello! I want to change my headlight bulbs. I have the Euro headlamps. Did you go with LED or just use new halogen bulbs? Any advice would be greatly appreciated!
Old Oct 8, 2019 | 06:51 PM
Bez74's Avatar
Hello David
Depends on your local laws. In Australia - you are not allowed to use LED in the headlights unless the car was designed for them - otherwise they shake too much and blind on-coming traffic.
In Aust, they can only be installed legally in off-road vehicles, for those that was not initially designed.
You can get some pretty awesome H1 (for the earlier models) or H4 (for the later models) light bulbs these days though
Steve
Old Oct 9, 2019 | 07:00 AM
malc4d's Avatar
I us a pair of these in mine
https://www.bettercarlighting.co.uk/...ewCat&catId=58
Old Oct 9, 2019 | 08:31 PM
Mike1610's Avatar
I went with the J.W.Speaker H4's 4000 4000k colour temp, awesome bit of kit.
TomR166
Jan 5, 2019 02:26 PM
lee cantrell
Feb 15, 2017 07:32 PM
Typhoon320i
May 1, 2015 06:31 PM
mannymux
Jun 17, 2012 07:07 PM
Mccalist
Dec 1, 2010 10:11 PM
