Help!! Intermittent Engine Failure..XJS
Old Jul 30, 2007 | 09:28 AM
XJ40ish's Avatar
Default RE: Help!! Intermittent Engine Failure..XJS
Ok...Is an XJS an XJ40? If it isn't why do we keep getting XJS questions in here, Help us out here Ken is you happen to be perusing this post..
Old Jul 30, 2007 | 12:35 PM
ken@britishparts.com's Avatar
There is no XJS forum so posters just put them where they want to. I guess they should be in the "other models" forum, but no big deal.
I would start with a manual fuel pressure gauge to see if you are really losing pressure. You may have a fuel pump that is getting too hot. It sounds to me more like an ignition module or coil, but it's too wide open until a little further testing.
Old Jul 4, 2016 | 01:21 PM
xjsv12's Avatar
Originally Posted by TheDrivenMan2
We have a 6.0 XJS with one of our Driven Man 6-Speeds that has an intermittent engine failure issue. It seems to quit when run hard and hot, stumbles quite a bit seconds before it quits and runs fine once cool. The car feels starved for fuel when it stumbles. Took the car out on Road Atlanta for a track tour and had to be flat bedded back to the pits after just a couple of laps in very hot weather. I may be attributing more to temperature than needs be, but driving home after Road Atlanta, cruising at low rpm in the evening the car never missed a beat. Anyone have similar issues or a possible solution? Thanks for your help.
I found this message. I have similar problem.
I changed sparks, coils, injectors, nothing helped.
Old Jul 4, 2016 | 02:57 PM
Mac Allan's Avatar
I had a similar problem a long time ago. It would run fine for short drives, but a long drive it would eventually shut down. Next morning, it would run fine. Drove me nuts.
It turned out it was a faulty wire going to one of the sensors the ECU requires for the car to run. Sorry I don't recall which sensor, but the way I found it was to let the car run and get very warm, then I'd start jiggling wires and the harnesses at various points. Eventually I found the failure point in a section of wire.
Old Jul 4, 2016 | 05:04 PM
superchargedtr6's Avatar
I will continue to say that those front and rear crank sensors on Marelli cars are now 20+ years old. Time and heat breakdown any magnet. Both are at play here. Replace your front and rear crank sensors, and make sure the air gap is correct while you are at it.
Old Jul 4, 2016 | 09:44 PM
Steve M's Avatar
Replace the coolant temperature sensor, the one that feeds the ECU. Once they start to fail (which they do quite quickly) they send errant signals to the ECU and sooner or later you end up with no drive and then no start.
The front crank sensor is only there to give a signal to the ECU to start the car; once the engine is running it serves no further purpose.
Old Jul 5, 2016 | 01:46 AM
Greg in France's Avatar
Which car and ignition system do you have?
Greg
Old Jul 5, 2016 | 05:31 AM
warrjon's Avatar
This is incorrect, the front crank sensor tells the Marelli when piston 1A is at TDC, the Marelli then calculates all ignition events from this pulse in conjunction with the engine speed sensor on the flywheel.
Old Jul 5, 2016 | 05:35 AM
"The front crank sensor is only there to give a signal to the ECU to start the car; once the engine is running it serves no further purpose."
Here is the 89 XKS supplement which describes the Marelli ignition system. The front sensor on the Marelli is the TDC sensor which controls timing, The rear sensor provides feedback for engine speed. The system simply will not run without either. However, I will say now as I have many times over in many posts.....these things are NOT sensors. They are small electromagnetic generators. The send a AC signal to the Marelli ECU. If the signal is weak or distorted, the car stops running.
http://www.jagrepair.com/images/Elec...Supplement.pdf
Old Jul 5, 2016 | 05:39 AM
warrjon's Avatar
As Greg said
What model and is it stock XJS 6.0L or has it been converted from an XJ40/X300 as the ignition systems are different.
There are too many small differences between all the iterations of the V12 to make any recommendations, apart from check ALL the wiring and connections to all sensors.
Old Jul 5, 2016 | 06:41 AM
Said to Driven Man 2 and to XJSV12 both! Bung the info on the signature lads!
Greg
Old Jul 5, 2016 | 02:26 PM
xjsv12's Avatar
Thanks for answers friends
Robert Hall's answer:
Hello Nikolai!
I remember you! I hope all is well.
The 6.0 cars have 2 fuel pumps. One for less than 2500 RPM and the other for more than 2500
My car was losing the flow from the low RPM pump. I replaced the pump and problem went away.
Thank you,
Robert Hall
The Driven Man - Improving Classic Cars
American Powertrain - More Gears More Fun
931-646-4836
Jaguar Performance Parts & Classic Car Performance - The Driven Man
Specialty Performance Parts, 5 and 6 speed Transmission Conversions and Accessories | American Power Train
Old Jul 5, 2016 | 03:01 PM
xjsv12's Avatar
She is 89
Engine 6.0 has swapped from XJ40 including a gerabox, wires and control units.
Then modified the gearbox, low 2.97 first gear and the control unit by TSI.
The engine is also light modified, like AJ6, enlarged throttle, intake manifold and cylinder head port.
Old Jul 5, 2016 | 04:09 PM
xjsv12's Avatar
This fault happened a year ago, as I understood it.
Ignition coil A bank failed at a speed of 100 km\h.
While I understood what happened, until I stopped, the catalyst is taken off on the road, exhaust pipe melted.
I disconnected the right injectors and drove ten kilometers to the workshop. Where I replaced the coil, spark plugs and catalyst.
After that I began to feel infrequent, non noticeable, like misfires. These misfires had a slow progress.
In this season very noticeable at rpm between 1000 and 2000 on the third and top gear with a light throttle.
Old Jul 6, 2016 | 02:43 AM
Which ignition system do you have? Nippondenso or Marelli?
I have heard (do not know) that there can be a honeycomb-type thing in the exhaust manifold or downpipe, if yours has this, maybe you have a blockage there?
Greg
Old Jul 6, 2016 | 02:55 PM
xjsv12's Avatar
Greg
I have Marelli.
After the catalyst has nothing, straight pipe 76mm (3.0").
I will measure the fuel pressure under load, after tomorrow.
I ordered a crankshaft sensor, both.
Old Jul 7, 2016 | 01:40 AM
I have Marelli.
Have you renewed the dizzy cap, rotor and leads?
Also, have you tried swapping the amps to see if the fault moves? Also, worth renewing the amp leads to the dizzy/coil, I seem to recall someone posting about an intermittent fault that turned out to be in thiss bit of the system.
Greg
Old Jul 7, 2016 | 07:30 AM
xjsv12's Avatar
Greg
Dizzy cup and rotor is genuine marelli's and HT leads is three years old. All that was checked after accident with coil.
I have amplifiers, will check it tomorrow with fuel pressure.
Old Jul 8, 2016 | 04:27 PM
xjsv12's Avatar
I renewed front crankshaft sensor, did not help. I'll wait rear.
Fuel pressure is norm, from 2.4bar to 2.9bar
