High efficiency cooling system upgrade
Old Apr 30, 2024 | 02:39 PM
  #161
Greg in France's Avatar
Originally Posted by Peter3442
115 Amp? That's giving around 2 horsepower in old money! The fans night hit that running at maximum, but that's only a brief peak demand. Most of the time, it must be much less. And the battery is there to deal with intermittent peaks. I would be inclined to see how things go with the 75 Amp alternator. If you see the battery is suffering, upgrade; otherwise stick with the 75 Amp.
I can assure you that with electric fans, whatever the theoretical position might be, you need the 115 amp alternator!
Old Apr 30, 2024 | 04:29 PM
  #162
Peter3442's Avatar
So far, mine have been OK, but the rest of the system is in very good order and the car hasn't yet seen any summertime traffic jams since the last restoration. I'll see how it goes and let you all know. I have a spare alternator somewhere in my pile of parts ....
Old Apr 30, 2024 | 04:47 PM
  #163
Peter3442's Avatar
https://www.startermotor-alternator-...350-2953-p.asp
Does this look correct? And, for those who have made the swap, did you also upgrade the cable?
Old May 1, 2024 | 01:33 AM
  #164
Yes, that's the one I have and bought from the same guys who were great. I use a normal V pulley and absolutely to problems with slippage.
Old May 1, 2024 | 05:02 AM
  #165
Peter3442's Avatar
I meant the alternator to battery cable.
Old May 1, 2024 | 07:40 AM
  #166
ascanio1's Avatar
https://www.startermotor-alternator-...350-2953-p.asp Does this look correct? And, for those who have made the swap, did you also upgrade the cable?
Brilliant! I'll buy this one, then. Do I need to tell my mechanic that he should modify the pulley, cable or ... ?
Old May 1, 2024 | 11:25 AM
  #167
Just tell him to fit the pulley from the old alternator, or ask the supplier to send one with the new alt. Then you just shim it up to be in line with the crank pulley using large washers. Your mechanic will have to drill out the bracket holes on which the alternator swings as the old one has an 8mm diameter long bolt but the new alt has 10mm diameter holes. He will also need a new 10mm long bolt.
Old May 2, 2024 | 03:42 AM
  #168
ascanio1's Avatar
Out of stock for 2 years now!
I think that the original was part number DAC5224E. Anyway, I found:I searched the forum (https://www.jaguarforums.com/forum/x...option-276743/) but, apparently, there is no clear alternative. Any advice, please?
Old May 2, 2024 | 07:14 AM
  #169
Peter3442's Avatar
Sorry that I sent you somewhere without a result. Since that company has (or lists) the original low amps generator, it might be worth asking them if they have a 115 Amp alternator for a later model V12, a Land Rover or other make that would fit the same brackets and has (or could be fitted with) the appropriate pulley. I have a vague memory of people using Land Rover alternators.
Old May 2, 2024 | 03:07 PM
  #170
ascanio1's Avatar
Oh, please! Don't apologise! In fact thank you, it's not your fault if they are sold out.
I already emailed them and Tom replied very quickly.
Basically, Tom remembers that the 75A unit was a left handed bracket whereas the 90/115A units were right handed brackets. If so, the only way of getting more power (without spending a lot) would be to make an LRB00284 (120 amp) fit. He suggested that I should be able to buy these quite easily, but it would take some work to make fit.
Any comments? Advice?
I'm unsure if my mechanic is up to manufacturering brackets.
Old May 2, 2024 | 07:25 PM
  #171
Jagboi64's Avatar
You can buy the 115A units on Ebay, I see used ones from the XJS/XJ40. They will probably need a rebuild, but that should be easy in Europe to find a competent Bosch rebuilder. The 115A units were introduced on the XJS in 1988.
Old May 3, 2024 | 12:32 AM
  #172
This will be fine:
https://www.autodoc.co.uk/lucas/13713781#alternator
as will this
https://www.autohausaz.com/pn/AL192X
as will this
https://www.autodoc.co.uk/autoelectro/10629950
Old May 3, 2024 | 07:29 AM
  #173
ascanio1's Avatar
Greg(s) and Peter, sorry, I am getting confused...
The only thing that I am not confused about is that, for this high efficiency cooling system (2 electric Spal fans + fridge in the back) my 75AMP might suffer.
Will I need to adapt the mountings on these? The triangular mountings where the bolts go, seem to be in a different position from where my alternator has them:
And, apologies, I am starting to get really confused now. Are any of the 3 above a simple drop in replacement for part DAC5224 (as gathered from the Jaguar/Land-Rover parts catalogues)? Is part LRB00284 (recommended by Starter motor and Alternator company) not good? They can procure LRB00284.
I attach images to help you determine which are better for my Double Six
75 AMP alternator
Alternator position on left of image
Alternator position
Old May 3, 2024 | 09:23 AM
  #174
Thomas,
ANY of the alternators I listed will be fine. They are all basically the same.
As to fitting it:
see this photo as marked up
The blue box shows the long bolt going through the bracket attached to the engine that provides the fulcrum for the alternator, allowing it to swing in and out as the belt tension is adjusted.
Depending upon the date of your engine, the holes in the bracket attached to the engine, through which this long bolt goes, MAY be 8mm in diameter, as will be the bolt.
The new alternator, which is essential in my view, will have 10mm diameter holes for the fulcrum bolt. All your guy has to do is unbolt the bracket (four large bolts, no problem at all with the alternator removed) and drill out the fullcrum holes. Dead simple; he will have no trouble doing it.
I have just been to the Turin motor museum; FANTASTIC. I am quite sure having seen such wonders as your countrymen created in the 1920s, that ANY italian would have no trouble fitting this alternator!
Old May 3, 2024 | 11:27 AM
  #175
ascanio1's Avatar
deleted
Old May 3, 2024 | 11:31 AM
  #176
ascanio1's Avatar
Ciao Greg, thank you.
Your advice makes sense and is very good news. I am sure that drilling out the holes will be very doable. Would I need a new pulley or would it be sufficient to adjust the body on the bracket?
I also received the same news from Tom of The starter motor and alternator company who is convinced that my alternator is already the 90/115A and, if I can find an LRB00350 - which I found - then it should fit right in without modifications.
Old May 3, 2024 | 11:37 AM
  #177
Peter3442's Avatar
After all, there are only two dimensions to match: the diameter of the holes on the lugs and their distance apart. The first is easily adjusted. The second is almost certainly the same. If there's a small difference it can be worked around.
Old May 3, 2024 | 01:09 PM
  #178
ascanio1's Avatar
Thank you all! You have been very helpful getting another issue sorted out!
Old May 30, 2024 | 07:02 AM
  #179
ascanio1's Avatar
Unfortunately LRB00350 is no longer available anywhere!
HERE jaguar lists DAC5224E as compatible, and I found this: https://www.auto-doc.it/ad-kuhner/14382651 which is DAC5224 - would this be the same part as DAC5224E? How important is that letter E at the end?
Old May 30, 2024 | 07:26 AM
  #180
ptjs1's Avatar
Tommaso,
The "E" just means that it is an Exchange Unit, where you supply your old unit as part of the purchase.
Paul
