Hood control module
Old Jul 29, 2014 | 07:01 AM
96xjsz's Avatar
Default Hood control module
Convertable Top not working electrical problem not hyd
Top works when I grd wires at the connection point of the Module
After extensive troubleshooting I have come to the conclusion that the HOOD CONTROL MODULE
on my 96 XJS is inop.
Tested wires relays switches
Reviewed diagrams
But before I buy one can anyone suggest something I maý have overlooked
Old Jul 29, 2014 | 07:09 AM
ptjs1's Avatar
96xjsz,
I think the only way to condemn the hood ecu is to know that the input signals are being received by it but that no output is then being sent to the relays.
The best way to do this is to backprobe the inputs on the ecu to confirm that it's receiving signals from the handbrake switch, transmission switch and the hood switch itself, yet not sending any signals out.
It's conceivable that the ecu has failed but, in my limited experience, not that common. When nothing at all happens, either windows operating or hood going down, it's nearly always the handbrake switch or the hood switch itself or, less likely, the transmission switch. If either the hood operates or the windows go down, then it's usually the relays.
Hope that helps
Paul
Old Jul 29, 2014 | 07:48 AM
96xjsz's Avatar
Ok sounds good
thanks for the come back Paul.
I am getting pwr from the hood ecu
I prove it by sticking my test light prob e in back side (ECU side) of the connector and attaching the wire end of the tester to ground
That makes it work hood goes up and dwn I can do that to the rear windows also
This tells me the grd info is not processed in the ecu
There's no short to grd in the hand brake tested and visually checked
I'm stuck away from home limited tools and support
It wòuld b nice to get this jaguar mystery solved.
Old Jul 29, 2014 | 10:10 PM
96xjsz's Avatar
Unhappy Hood inop still
Well I still can't seem to get the
hood to work from inside the car
Again I can make the hood go up and down from the trunk relay area.
at the hood module ecu
I removed the switch and jumped the wires to prove continuity.
It looks to me like the ground is not making a connect.
ANY IDEAS
I found a Hood ECU for 200 but If i put it in and it blows well you know
It blows.
Larry
Steviedee1st
Nov 28, 2023 06:32 PM
XJsc-guy
Sep 25, 2015 11:09 AM
JeffinSwitz
Sep 16, 2015 01:44 PM
BruceG
Sep 15, 2015 05:47 AM
jaguarbill
Sep 5, 2015 11:43 AM
