Hood Part Info
Old May 24, 2012 | 12:58 PM
davbell22602's Avatar
Default Hood Part Info
Where do you get the rod ball fittings for the hood struts on a 77 XJS?
Old May 27, 2012 | 09:37 AM
Anybody?
Old May 27, 2012 | 09:56 AM
Greg Edge's Avatar
They don't use a ball and socket mount. The hood struts have eyelets.
Old May 27, 2012 | 09:59 AM
Where do I get the eyelets at?
Old May 27, 2012 | 08:05 PM
Greg Edge's Avatar
they are part of the hod support gas strut.
Old May 27, 2012 | 08:08 PM
Ok, I talking about the piece thats bolts to inside of the fender under hood. Its gray colored piece that you run bolt through to attach the hood strut on the inside of the fender.
Old May 27, 2012 | 08:40 PM
Greg Edge's Avatar
Look in your parts catalogue. If you do not have one buy the DVD for your car from JDHT.com. It has service and parts info.
Old May 30, 2012 | 07:46 AM
joedonbob's Avatar
i recently replaced my hood struts. only one was there when i initially bought it and was using half a pool cue to prop the hood up. bolts and strut were missing. i just went to my local auto parts machine shop/hardware store and bought the bolt, sleeve, and nut that worked and voila. be sure and match your threads though.
now i just wish i'd have bought more pressure so i could do the automatic lift hood without the hook.
Old May 30, 2012 | 07:36 PM
Greg Edge's Avatar
have to be careful about too strong of a lift support. Some have spent hours saving a few bucks by buying a generic version or one from another vehicle. Hoods will bend when closing if they are too strong. Personally I can't understand the obsession of some that are always trying to find a different part that will work when you can buy the correct one.
Old May 31, 2012 | 09:06 PM
Couldnt find it in the parts catalog. I need the hood lift brackets. I'll post a pic of what it looks like.
WinterJag
16
Oct 9, 2015 07:49 PM
redrover41
23
Sep 25, 2015 01:33 PM
martybmw
Sep 5, 2015 11:59 PM
edtexas
Sep 4, 2015 08:20 PM
