Horsepower/ torque capacity of ZF 4 speed
Old Feb 5, 2009 | 12:38 PM
benitothebandito711's Avatar
Default Horsepower/ torque capacity of ZF 4 speed
I've got a 96 with the 4 speed ZF tranny, and I'm considering doing a custom supercharger or turbo set up and anyone know how much this tranny can take, or where to get parts to beef it up?
Old Feb 5, 2009 | 01:09 PM
JagtechOhio's Avatar
Greetings,
The pragmatic answer to that question is that Jaguar likely didn't think so, or found out the hard way of a shortcoming. The 4HP24 was used in all XJ40 and normally aspirated X300 as well as your car, with what I would consider to be exceptional reliability. The '95 to '97 XJR 6 cyl was fitted with a different transmission, the designation for which I would have to research. So I assume that the increased HP was the reason for the transmission change.
Swapping out the powertrain and electronics from one of those cars would get you there quicker, and get you there quicker.
Old Feb 5, 2009 | 01:37 PM
1995-1997 (X300) Jaguar XJR 6 cyl. uses a GM 4L80E automatic transmission in the U.S.
Old Feb 5, 2009 | 02:45 PM
will the 4l80e mate up to the aj16 in the 96 xjs, or do I need a special bellhousing to go along with it?
Old Feb 5, 2009 | 03:11 PM
Different transmission adapter plate at the rear of the block, added spacer for flexplate, different flexplate and cooler pipes, different TCM , different harness, probably more that I didn't look any further for. I'll stick with my first answer, find an XJR and swap it all out. You'd likely have to fab your own driveshaft and intercooler.
The trans wouldn't be hard to source by itself, and XJ12 used the same one too: everything else would be pure luck to find individually, and I suspect that alot of new items are NLS. Pistons for XJR have been on intergalactic backorder for years.
Old Feb 5, 2009 | 03:50 PM
hmmmm maybe just a completely different direction for the powertrain/drivetrain might be less of a headache
Old Feb 5, 2009 | 04:42 PM
Doug's Avatar
Or, frankly, a different car.
I hate to squash anyone's enthusiasm and "can do" spirit but if you want less of a headache then the idea of going out and simply buying a car that gives you the level of performance you want is at least worth considering.....isn't it?
Nice XJRs can be bought for peanuts :-)
<shrug>
Old Feb 5, 2009 | 05:45 PM
Well, Benito, that's up to you. I was just trying to answer your question. I think I'd go Doug's route, I own a '97R waiting for an engine that I'm dying to drive. There is a website somewhere of a guy who has installed the drivetrain in an E Type, and that would be a bigger feat.
Did you receive the quad headlamp assemblies yet?
Old Feb 5, 2009 | 10:33 PM
No I haven't recieved the headlamp assemblies yet, last I checked they were somewhere between ohio and here! haha I'll let you know. Yeah I know just getting a car that is more condusive to the types of things I would like to do would be easier, but I'm stubborn so who knows. Then again, I've always got a million ideas running through my head, if only had the money to play them all out!
Poet
Feb 7, 2025 02:18 PM
Poet
Oct 2, 2015 09:00 AM
Doug S
Sep 30, 2015 02:03 AM
caldoofy
Sep 28, 2015 08:43 PM
Jaguar Forums Editor
Jaguar Press release
Sep 25, 2015 11:58 AM
