How do I check the Voltage draw on my Electric Fans?
Old Aug 4, 2016 | 06:02 PM
orangeblossom's Avatar
Default How do I check the Voltage draw on my Electric Fans?
I'm no Auto Electrician, so is there a very simple way of being able to check the Voltage draw on my Electric Fans, so I can see if the alternator will be able to keep up.
Old Aug 4, 2016 | 10:18 PM
flyinlow's Avatar
the voltage draw will be battery voltage what you need to be concerned with is amperage draw. The easiest way to test is an inductive amp meter. You can get an inexpensive one for what you are doing just make sure the battery is fully charged and engine running because as voltage goes down amperage goes up. https://www.amazon.com/Uni-T-UT210E-...n+dc+amp+meter
Old Aug 5, 2016 | 12:00 AM
BC XJS's Avatar
watts ÷ volts = amps . simple as that
Old Aug 5, 2016 | 04:18 AM
warrjon's Avatar
Yes get a 0.1ohm 100Watt resistor and put it in series with the + power lead, measure the voltage drop across the resistor and current=voltage/resistance. You could use 10x 1ohm 10Watt in parallel.
so a 10volt measurement and 0.1ohms
10amps = 10Volts / 0.1ohms
Old Aug 5, 2016 | 05:28 AM
jimbov8's Avatar
Why make things easy when you can make them difficult.
Clip on ammeter from any auto motive store, clip it around one lead only and read the scale, simples.
Old Aug 5, 2016 | 06:18 AM
yarpos's Avatar
As BC says the answer to your question is stamped on the fans.
The issue then is what to do with the information. You would need to know the amp rating of your alternator , and the existing current draw with AC on to know what headroom you have. That is where maybe the later suggestion for the ammeter might come in handy.
Old Aug 5, 2016 | 07:39 PM
Jagboi64's Avatar
I think the ones on my X Type are around 30 amps.
Joe Hochrein
Aug 3, 2016 09:06 AM
Kitesurfer
Jun 21, 2016 05:01 PM
Blondie 1
Jun 16, 2016 02:16 PM
JimboDee
Jun 9, 2016 12:25 PM
madlarry
Non-Jaguar Vehicles
Jun 4, 2016 12:45 PM
