How do I reattach the facelift rear bumper?
Old Jun 27, 2019 | 09:26 AM
Vee's Avatar
Vee
Default How do I reattach the facelift rear bumper?
Are there some connection parts I’m missing to prevent the rear bumper from hanging under the car? (See picture)
Old Jun 27, 2019 | 10:37 AM
ptjs1's Avatar
Vee,
The leading edge of the bumper cover slides into the edge of a flattened-s type strip which is probably still riveted to your car.
It effectively slots into that strip and is held through the tightness of the strip. In my experience, it often wants to pull out from that strip. After repeated episodes of it falling out, I then screwed in 3 short self-tappers through the strip and into the leading edge of the plastic bumper cover; one at each end and one in the middle. This completely resolved the problem of the edge coming loose.
Hope that makes sense. If you get under the car, you'll see the strip under the car.
Paul
Old Jun 27, 2019 | 11:36 AM
Vee's Avatar
Vee
Originally Posted by ptjs1
Vee,
Paul
I get exactly what youre saying. I slid it back in there several times already, and it keeps coming back out! I cam here looking to see if there was something I was missing. Seems like I'm not. I'll be using your solution. Probably use a couple of speed nuts to keep it in place.
Thank you!
Old Jun 28, 2019 | 11:34 AM
Vee's Avatar
Vee
Took a closer look at the clips and I see that the guy that repainted my car stretched them out... Even with pliers, I can't get them tight again.
Old Jun 28, 2019 | 05:11 PM
Jagsandmgs's Avatar
There were already some drain holes or something in the flange/ slot on my car, so I drilled a couple holes on the bumper nearby and zip tied the flappy bit back on. The flange itself is supposed to have additional metal clips but they were broken.
Johnken
Dec 11, 2018 01:23 PM
treborefir
May 24, 2018 01:42 PM
Tcasmarcus
Aug 10, 2017 09:35 AM
JonJag
Nov 8, 2014 12:39 PM
Suki
XJ40 ( XJ81 )
Oct 10, 2011 02:31 PM
