How does A/C work
Old Mar 27, 2013 | 04:55 PM
macdoesit's Avatar
Banned
Default How does A/C work
When AC set at 65* if you pull out on thermostat should it blow colder than 65*? when I pull out on thermo it blows hot.
With thermo pushed in Temp outside is 70* compressor will not engage.
It is full of freon.
Any help Thank you.
Old Mar 27, 2013 | 10:04 PM
macdoesit's Avatar
Banned
If the ambient temp is 65* or below will compressor come on ?
Old Mar 27, 2013 | 10:27 PM
Doug's Avatar
As I rcall when max cool or max heat is dialed up, the system no longer looks at ambient/cabin temp.
Even if I'm not remembering correctly on that point, the pull-for-manual-control feature certainly defeats auto temp regulation.
As for the compressor not engaging....
Start with the easy stiff. Have you checked the fuses?
Old Mar 28, 2013 | 08:51 AM
macdoesit's Avatar
Banned
Yes, have checked all fuses. Can not find the relay switch.
Old Mar 28, 2013 | 10:30 AM
Vee's Avatar
Vee
Have you checked the thermal fuse? Its located in the rear of the compressor in contact with the suction side gas, whose pressure drops and temps rises with a low refrigerant charge. The thermal fuse is a sealed unit containing a heater and a meltable fuse.
There does seem to be a relay under the vacuum actuator motor.
You should invest in a service manual.
Jeh
XJ40 ( XJ81 )
Oct 13, 2015 09:23 PM
tberg
Sep 7, 2015 07:32 AM
user 652867429824
Sep 5, 2015 12:53 PM
philwarner
Sep 5, 2015 10:05 AM
OkieTim
Sep 2, 2015 12:48 PM
