How often should fuel line be replaced?
Old Oct 12, 2014 | 11:41 AM
RogB's Avatar
Default How often should fuel line be replaced?
Having watched my 75 Merc go up in flames when the fuel line split and sprayed gas all over the hot engine, any advice re my 92? Car has only 30,000 original miles but age of car probably more of a factor.
Don't care to go through that again!
Old Oct 12, 2014 | 11:45 AM
sidescrollin's Avatar
yeah hoses become damaged from heat and oxidation (age). The general rule for fuel systems is usually around 15 years, but its depends on where you live. So it is mostly up to a personal inspection. Generally speaking a car made in 1992 definitely needs new lines
Old Oct 12, 2014 | 07:06 PM
superchargedtr6's Avatar
With the V12 XJS, I would say more like 5-10 years. I have owned, driven more cars than I can remember over my lifetime, yet none have equalled the underhood heat of our beloved V12 XJSs.
Old Oct 13, 2014 | 12:27 PM
I replaced multiple hoses on my XJS as soon as I got it in 2010 and I live in florida. There is no way any of them will need to be replaced in the next year. Like I said, its mostly up to personal inspection. Hoses are made much better than they were a long time ago, so its worthy investment.
Old Oct 14, 2014 | 07:15 AM
baxtor's Avatar
new hose ferrules will cost you a few dollars and a couple of metres of new hose is enough to renew the set-up under the bonnet so why not.
Old Oct 14, 2014 | 09:40 AM
have fun finding the stupid ferrules though. takes way more effort than necessary
Old Oct 14, 2014 | 03:50 PM
baxtor's Avatar
I am in rural Australia where very little is easy to acquire and they were not a problem. Heaps online too, they seem to be a common enough size.
Old Oct 14, 2014 | 06:13 PM
in American the word almost doesn't exist. I found one place that sells them for a dollar a piece and another guy that sells them out of his home. that is all
Old Oct 14, 2014 | 07:31 PM
baxtor's Avatar
fittingsandadapters.com is one i have saved but did not use. Las Vegas address
Old Oct 16, 2014 | 09:53 AM
RogB's Avatar
Can anyone tell me if this is the correct set to fit my 92 xjs? Is cost in ballpark?
Thanks!
http://www.v12s.com/fixjscc.html#fihosecaps
Old Oct 16, 2014 | 11:21 AM
No. Stay far far away from that. There is another company that sells basically the same pack.
The ferrules can be found for like a dollar a piece. So thats 24 bucks. You need like 3-4 feet of hose so another $20 or so. I don't recall how much the seals are for the injectors, but its not 100 more dollars. That is a ripoff.
Old Oct 19, 2014 | 12:18 PM
TheWarlock's Avatar
Thanks for the heads up, got a link or part number or specs for the ferrules or hose?
Old Oct 19, 2014 | 12:41 PM
I think we need to figure out the specs for them, because when you look for ferrules it is hard to find anything that looks llike the ones for the jag. I think this is mostly because a lot of the available ferrules are not flared like the ones that come on the car, but I don't see why that would make any difference.
maybe someone can find a link though, I can't seem to find them again.
It is worth nothing though, that if you have some razor blades and maybe an X-acto set, you CAN cut the hoses out from the inside of the ferrules and reuse them.
Old Oct 22, 2014 | 12:13 PM
RogB's Avatar
Default How to take out relay?
http://i36.photobucket.com/albums/e3...g?t=1413990951
Tried to paste image in window, had problems so pasted link instead.
Can't figure out how to remove relay without taking apart bracket assembly. Its lid does not give enough clearance to take relay out and lid is part of bracket.
I'm no doubt missing something basic here!
<<Sorry, posted this on wrong thread.>>
Old Oct 23, 2014 | 03:55 AM
baxtor's Avatar
mine just slides up and then out. The socket the relay plugs into is what engages the peg though so the socket with relay attached is removed before unplugging the relay itself.
Old Oct 23, 2014 | 07:20 AM
Doug's Avatar
FWIW I get the ferrules from Dave at......
Jaguar Fuel Injector Service
I *think* they're NLA from Jaguar.
Old Oct 23, 2014 | 07:26 AM
Doug's Avatar
Or maybe not.
Google EAC7876 and lots of hits, in Jaguar packaging in some cases
eac7876 - Fuel Injector Sleeve
Old Oct 23, 2014 | 08:51 AM
XJSFan's Avatar
I have not done my hoses yet because they still feel somewhat soft and look fine. BUT I am considering it for a Winter project...
Old Oct 23, 2014 | 06:16 PM
RogB's Avatar
Default confused about fuel hoses
Various kits sold on the net show 2 longer hoses and 10 shorter ones. I thought each injector required a hose, but since I assume the longer hoses go between the fuel rails that seems to leave 2 injectors without hoses. Does that mean there are only five injector hoses on each side?
Also is it possible to access the injector hoses for inspection without removing anything?
Is there a link that shows detailed info on replacing injector hoses?
Old Oct 23, 2014 | 10:05 PM
you just haven't looked at it so you aren't remembering correctly. The HE square rail has a fitting on each side for the inlet and outlet of fuel. The longer hoses go to the front 2 injectors.
there ARE some things that have to come off, but not much is in the way.
I am not a fan of bernard emblems methods or ideas on engineering and car repair (like soldering copper pipes for the cooling system), but his website does have some useful pics and advice, as long as you consult with yourself about whatever it is he is saying. He has several write ups about changing his pre-he rail to an HE rail and eventually fabricating his own. There are probably some useful pictures and ideas there.
