How to Replace the Tag Light Lenses
Old Nov 4, 2015 | 10:06 PM
workworkwork's Avatar
Default How to Replace the Tag Light Lenses
This is my first attempt at sharing a how to post here. I found that my tag light lenses had crumbled with age and were hanging down. So, I set off to replace them myself. The first couple of pictures show how they had deteriorated.
Attached Thumbnails How to Replace the Tag Light Lenses-20151101_153358.jpg   How to Replace the Tag Light Lenses-20151101_153404.jpg
Old Nov 4, 2015 | 10:11 PM
There are a series of bolts that hold the whole jaguar trim assembly that houses both the tag lights and the reverse lights. I removed all the bolts and that assembly came loose. I then used painters tape and taped up the paintwork around where the assembly was so that I would not scratch or damage the paint. But to my surprise I found that the old assemblies were riveted on but the new assemblies screw on. You have to carefully drill out the rivets but don't enlarge the holes because the screws on the new ones require the size of the old hole to work. What I did was carefully drill the top of the rivet off with a larger drill bit then drill the center of the rivet off with a smaller drill bit. Here you see a picture of the original rivets.
Old Nov 4, 2015 | 10:20 PM
After drilling out the rivets I was able to screw in the replacements. Then I removed the tape and bolted back the whole trim piece. This turned out to be a relatively easy do it yourself activity. I hope this helps someone who has the same issue with their tag light lenses.
Old Nov 8, 2015 | 07:39 AM
kenatofc's Avatar
Good job.... It is always best with procedures and photos.....
ken in wv
Old Nov 8, 2015 | 07:11 PM
Thanks Ken.
jaguarxjl
Apr 21, 2025 08:18 AM
hdavidson
Nov 22, 2015 12:01 AM
nherndonxk8
Nov 4, 2015 02:07 PM
RagJag
Oct 31, 2015 10:32 AM
ttstanescu
Oct 31, 2015 09:58 AM
