I guess this goodbye
Old Mar 13, 2016 | 12:40 PM
Qgregg's Avatar
Default I guess this goodbye
Well i am not a rich person, and i am not a mechanic. Looks as if i really messed up this time buy cracking the tube that runs to the AC evaporator. I was replacing the hose when the bottom spanner sliped, the hose fitting was on sooooo. Tight....evidenty it is now leaking pretty good. With air pressure on the system i can barely get my fingertips to the firewall where its leaking...i can feel the air coming out.....this i think is way over my head...only option i see which breaks my heart is to sell my 88 xjs...thanks to everyone that has helped me over the years......you fellas are a great bunch of chaps.......
Cheers...............and God Speed..
Old Mar 13, 2016 | 02:12 PM
JagCad's Avatar
Aww. hold on a bit. sleep on it at least a night, A few is better.
As I understand it, it is the Ac line. That is freon leaking away.
The only down fall, is no AC. Other than that, it is still a nice looking and running car.
But, it may be the Ranco valve line that is busted. No fun to replace, but far better than the evaporator itself.
And, even that is doable. Major task, but doable.
Carl
Old Mar 13, 2016 | 03:58 PM
Qgregg's Avatar
Really? ???
Carl
really???
Old Mar 13, 2016 | 04:03 PM
Qgregg's Avatar
Originally Posted by Qgregg
really???
cant get to exactly where , but if i squeeze my fingers in behind where the hose nut screws on and into the firewall is where i feel air and it could be just on the otherside of firewall........so frustrated....what shouldve been a easy hose change.
Old Mar 13, 2016 | 04:36 PM
JTsmks's Avatar
What do you mean "feel air"? Any refrigerant in the system should be long gone if you breached the line/fitting etc. If the hose is off or loose there would be no more "air" to feel.
Old Mar 13, 2016 | 05:18 PM
Mac Allan's Avatar
Take a deep breath and relax.
We've all been there, don't give up.
Old Mar 13, 2016 | 05:35 PM
JTsmks's Avatar
Drink a lot! Sleep, drink some more! Sleep, then if your still not sure have another drink! Then make up your mind. Remember, it's only nuts and bolts, not brain surgery.
Old Mar 13, 2016 | 05:36 PM
Qgregg's Avatar
The system is free of all refrigerant......with all hoses connected.....i put air pressure on with a compressor......feel air blowing out as stated above....wont hold vacuum....or pressure....
Old Mar 13, 2016 | 05:53 PM
Steve M's Avatar
It's only aircon.
I have 4 cars with it and it doesn't work on any of them.
Take the whole system out; the car will be lighter, there will be less load on the engine and you will go faster.
If it is hot outside then open the windows and drive really quickly.
Old Mar 13, 2016 | 07:11 PM
MHF25's Avatar
Where are you in South Carolina? There are several viable Jaguar technicians in the low country area. I just had my AC compressor replaced by tech who has been in business for over 25 years..
Old Mar 13, 2016 | 07:22 PM
Qgregg's Avatar
Location is Florence S.C
Old Mar 13, 2016 | 08:07 PM
Qgregg's Avatar
Sad thing is i posted several weeks ago i was going to replace the hose and doug said be care and support the fitting because if the evaporator tube breaks im sunk.....i thought i really had the spanner on there good to back it up.....but that hose fitting was so tight had to use a bar on the wratchet.....it didnt move hardly any, but guess it twisted just enough......the pic i attached is what i could find....i think its break is right it the plate......wondering if i may could get some jb weld on it or something.....
Old Mar 13, 2016 | 10:59 PM
Doug's Avatar
Well, when you're sunk there's nothin' to do but re-float the boat!
No matter how you slice it replacing the evap core is a big project. But also perfectly doable if you work slowly and methodically and keep track of everything that you take apart. Look at it this way: all it is, is just taking stuff apart and putting it back together again!
The upside is that your '88 has the Delanair Mk III system which is a bit easier to contend with than the older Mk II type.
I agree that you should sleep on any decisions for a couple days.
Old Mar 14, 2016 | 02:00 AM
Greg in France's Avatar
Originally Posted by Steve M
It's only aircon.
Really good advice!
And if you do have to replace the evaporator, as Doug said, it is doable if you have covered space. A new core is expensive, but I am certain you can find a second hand one from a breaker, or from a Forum member. You have definitely cracked the evaporator tube and replacing it is a dashboard out job. I have done it, and it is not nearly as bad as you think it will be when you start out. You do not have to be a mechanic to do it, just have some space and some normal tools, and be able to follow the step by step we will all help you with.
But just check that you HAVE broken it, and not just in fact loosened the nuts. Are they still tight?
Greg
Old Mar 14, 2016 | 06:32 AM
Qgregg's Avatar
Really good advice!
Greg
I'll have to give it a look see. Taking a couple days to breath and take it all in.
Old Mar 14, 2016 | 09:55 AM
MHF25's Avatar
Contact David at EverydayXJ.com. He is in Rowland, NC (near Salisbury) which is very close to Florence. David deals in all types of Jaguars. He has an extensive inventory list. He does not carry much in XJS inventory, but has numerous interchangeable reference parts. His website is:
www.everydayxj.com/
Last edited by GGG; Mar 17, 2016 at 03:00 AM. Reason: Remove eMail address from quote and replace with we link
Old Mar 14, 2016 | 11:38 AM
Qgregg's Avatar
www.everydayxj.com
Thank you much !!!!
Old Mar 14, 2016 | 03:54 PM
BC XJS's Avatar
Don't get rid of the just because the ac is gone. Drive it for a while and revisit the repair later. Its only ac
Old Mar 14, 2016 | 06:48 PM
Qgregg's Avatar
Ok Gentleman, not really sure weather good news (i feel it is ) or still sunk? I cut the hose off of a empty can of refrigerant so to be able to get air into the AC System.....with soapy water in hand i sprayed the area in question.......BUBBLES !!! on the other fitting coming off the tube into evaporator....im posting a picture of the discribed area and you can see the other copper tubing smaller tube smaller fitting........looks as if the bubbles are coming from the bottom of other smaller fitting.......had been reading about changing spark plugs and the items that need removal.....is this a possibility to fix both issues of course the AC and change spark plug wires...all from the bonnet side ......what do you all think ?
Old Mar 14, 2016 | 08:47 PM
Doug's Avatar
Not sure if I follow but there is a very small diameter tube, with a screw-on nut/fitting, that's part of the expansion valve... #9 in this picture. Is that what you are talking about?
Air Conditioning Evaporator-3.6/5.3 Litre - Parts For XJS from (V)139052 to (V)179736 | Jaguar Heritage Parts UK
The expansion valve itself bolts to one of the evaporator tubes. I can be replaced separately...about $25 for a new one.
