I had an unusual experience this morning
Old May 29, 2021 | 01:08 PM
petemohr's Avatar
Default I had an unusual experience this morning
My alternator died. A friend said he had one I could have. Turned out it was the wrong type but the diode pack was the same so I pulled mine, swapped the diodes and took it to Auto Zone for a quick test. It tested OK so I reinstalled the alternator. Put everything back together and it fired right up. Charging like a champ.
What's unusual? No problems. No dropped/lost tools, bolts, or nuts. No parts left over. The entire process went so smoothly I just had to tell someone!!!
Old May 29, 2021 | 01:21 PM
Spikepaga's Avatar
great! That’s a great feeling
about to do a starter change on my X type. Should take 30 minutes to 1 hour . Send those vibes in this direction please!
Old May 29, 2021 | 08:24 PM
Brewtech's Avatar
Smart move
Old May 29, 2021 | 08:30 PM
Thorsen's Avatar
Must be a full moon - I had an alternator issue in my MGB today. The case split at the mounting ear and I had to use a ratchet strap to hold it together for the drive home. I stole the CS-130D I was putting in my XJS to keep the MGB on the road. I didn't lose any finger tips or nuts and bolts!
This is how I nursed it home for 10 miles...
When I got home and removed the alternator...
Here's the CS-130D I stole from my XJS...
Old May 30, 2021 | 05:20 AM
BLOODY WELL DONE>
BUT
You only have 1/2 the engine, so anything you drop MUST fall out the bottom.
I need a drink
WELL DONE AGAIN.
Old May 30, 2021 | 08:08 AM
petemohr's Avatar
Originally Posted by Grant Francis
. . . . anything you drop MUST fall out the bottom.
Ah, If only that were true! ;-))
John-Melanie
Jan 8, 2026 02:59 PM
David F.
Jul 3, 2019 12:54 PM
FresnoJim
Sep 4, 2016 09:41 AM
estunum
XJ40 ( XJ81 )
Mar 2, 2011 08:55 PM
