I need help!
Passenger side inside trunk there is something missing either a amp for the radio or this car also has a phone power antenna????? this is a 92 convertible v12
Give us a clue, what car have you got? Could be a multi CD player?
I suppose where you have posted it is a bit of a clue! DOH!
Last edited by Jag u are; May 27, 2013 at 04:48 PM. Reason: Just noticed the posting area
do you have remote locking, anything plugged into that big connecter ? the radio antenna is just in the same place not connected to the alarm. coax cable is for remote locking (on mine)
The power antenna unit should be mounted on that brass-coloured bracket. The green relay in your photo is the antenna relay (delayed retraction when you turn off) which runs off that 10A fuse also visible in the photo. I guess you don't have a power antenna. I'm basing all this on my 92 coupe.
Mark,
Did you read my posts above....?
Your electric antenna is missing and the white connecting block and black plug are for the xjs 1992 my security system factory alarm, remote door lock controller that was fitted to the facelift '92 my. I fitted the kit myself as wanted the remote doors. Just plugs in.......see link l posted above.
I would post a photo if only l could.........Damm, hate being over 12
