Issues with a rebuilt steering rack
Old Mar 30, 2025 | 07:16 PM
Albertajag's Avatar
Default Issues with a rebuilt steering rack
Hello All,
I have a LHD 1989 Jaguar XJS. My steering rack developed a serious leak and was in need of a rebuild.
I decided to order a rebuilt steering rack. Pictured below is the rebuilt steering rack (silver) and my old power steering (black). I have verified both steering racks are Adwest "POW-A-RACK" steering racks and the steering rack dimensions are the same.
I am a hobbyist mechanic and enjoy working on my Jaguar and this is my first time replacing a steering rack on any vehicle.
This may be a dumb question, but I am lost on why the inner tie rods between the racks are different lengths?
Using the steering tower as a reference point, there is about a two inch difference in length among the inner tie rods between both racks (tried to demonstrate this with the purple lines). However the overall length between the racks + tie rods are the same (yellow line).
Can the difference in tie rod lengths be potentially due to one rack being centered and the other not? Not sure what else as I believe the inner tie rods are identical parts for both sides.
Old Mar 30, 2025 | 08:28 PM
RGK20m3's Avatar
Looks like a turn off center. If you look opposite the pinion, you will see a cap with a 5/16” hex head plug (or a grease fitting of same hex). Remove it, and stick the shank end of a 3/16” drill bit in with light pressure. Then rotate the pinion until you feel the bit drop a slight amount. That is center.
Old Mar 30, 2025 | 08:35 PM
Albertajag's Avatar
I appreciate the prompt reply. Can the same centering be achieved using a wrench and turning the spline on the steering tower? Thank you!
Old Mar 30, 2025 | 08:52 PM
RGK20m3's Avatar
Yes you turn the pinion to center it, just as the column would turn it.
egold56
E type ( XK-E )
Jan 10, 2023 08:23 PM
cafexjs
Apr 8, 2022 07:06 AM
laguillotine
Jul 3, 2019 08:57 AM
mrobinson
Mar 23, 2016 06:17 AM
NTL1991
XJ40 ( XJ81 )
Sep 4, 2015 06:01 PM
