Jaguar XJS Celebration 1996 4.0 Cabriolet
Old Aug 11, 2025 | 05:01 AM
Jag06530's Avatar
Default Jaguar XJS Celebration 1996 4.0 Cabriolet
Hi, the cooling fan is clashing with the shroud and ask for opinions were the problem could be;
Looking at the explode view there's probably 4 areas of concern
11 - Jockey pulley play
8 & 9 - play in the pulley / pulley bearing
2 - Torquatrol unit damage spinning of centre
Difficult to sense any play with hands but when the car is cooling it clashes occasionally
Another possibility worn engine mounts again they look ok but can't measure old vs new
Any thoughts more than appreciated
I
Old Aug 11, 2025 | 07:17 AM
Greg in France's Avatar
Most likely a failed gearbox mounting, if the fan is hitting the top of the shroud hole.
Old Aug 12, 2025 | 07:27 AM
Vee's Avatar
Vee
For my car, it was the engine mounts. One side delaminated, which you'll only be able to tell when removing. I would start there.
I think the fan was more prone to making contact when I made left hand turns, which I think means that the passengers side mount had failed.
jafo1970
Apr 14, 2023 09:23 PM
twojags1992
Jun 28, 2022 05:26 PM
melhookv12
Dec 5, 2016 10:42 PM
cdmarano@gmail.com
Nov 28, 2009 11:24 AM
patrickw813
Dec 29, 2008 01:03 PM
