Jaguar XJS ECU vacuum line replacement
Hi forum, i just found out that my ECU line doesnt hold any pressure, so assume its leaking somewhere, i have already found one leak near the wheel arch, metal line was rusted out, i cut it and it still leak somewhere, i have replaced the rubber line from ecu to the metal line at rear, but it doesnt help, so leak is either somewhere at metal line, or rubber line from crosspipe, both of them is hard to examine, since you cant reach them without removing parts, so i just think to abandon metal line and put another one in parallel. What hose type will be a good fit for that job?my thinking is that soft silicon lines that i used in the engine bay probably wont be a good fit, since on the longer distance they can "play" (or not?) So what shall i use?
Sure, i will try to find a leak spot, mb its somewhere visible , but still prefer to have a plan B
Thank you
Thank you
Thanks, im actually measuring pressure with ecu disconnected and crosspipe section disconnected and plugged. So its only line and nothing else! Thanks for the advice on efi fuel line!
arctic_man
Jul 31, 2020 05:59 PM
