Jaguar XJS LH front door hinge spring
Old Aug 19, 2013 | 02:23 PM
MHF25's Avatar
Default Jaguar XJS LH front door hinge spring
Attached is a photo of the LH Front door spring hinge that is broken (on square bottom end). I need a replacement. I have a 93 XJS Coupe. Don't need the whole hinge, just the spring.Jaguar XJS LH front door hinge spring-100_1949.jpg. Front door will not stay open without this spring. Thanks..
Old Aug 19, 2013 | 09:27 PM
JTsmks's Avatar
Is there a way to replace just the spring? Mine broke and I bought a spare hinge but have procrastinated changing it out. Check with David Boger at "everydayxj" he may have one on a car he's parting.
Old Aug 19, 2013 | 09:30 PM
AllanG's Avatar
Jag sold the whole hinge assembly incl the spring as one item but it's NLA. You might look on the net for someone parting out a car and see if they'll sell you the spring.
If I were you I'd try to find a local metalshop and see if they could fabricate for you. Should be pretty simple.
Cheers,
Allan
kurtomatic
Feb 12, 2024 06:58 AM
DrScientist
Dec 9, 2015 07:36 PM
aquifer
Aug 29, 2015 04:54 PM
Mr.B
Aug 28, 2015 02:14 AM
