Junkyard spring removal
Old May 31, 2025 | 02:01 AM
Jagboi64's Avatar
Default Junkyard spring removal
An XJS has come into my local self serve junkyard and I want to take the vertical link (upright) from the front suspension. Of course, that means taking the tension off the springs. My usual method is the 4 threaded rods, however, there isn't enough space between the bottom of the spring pan and the ground to use the rods.
Is the shock strong enough to hold the spring during removal, or is this asking for trouble? Obviously I'm concerned about doing things safely, or I wouldn't be asking. No jacks, torches or grinders are allowed in the yard, otherwise lowering it down on a floor jack would be the easiest course of action.
Old May 31, 2025 | 03:45 AM
rgp's Avatar
rgp
I'v changed top arm bushes & lower ball joints on front suspension with just jacking under the spring seat but you won't get your jack back if your removing the carrier. Not sure if I would trust the shock though
Old May 31, 2025 | 04:36 AM
Look around, a road wheel, under he pan, lower the thing, thus compressing the spring, take what you want.
BUT BUT BUT
Someone is going to get a face full of spring sooner or later.
SOOOOOOO
After your take, raise the thing CAREFULLY, and from as far to one side as possible, to release that spring for the next guy.
DOABLE, but I would NOT do it now, too old ans slow.
Old May 31, 2025 | 08:24 AM
icsamerica's Avatar
I wouldn't recommend removing a spring like that. Try buying a complete IRS or call David at everyday xj. He'll gladly sell you the control arms
Old May 31, 2025 | 08:28 AM
Doug's Avatar
I surely don't know; never tried. I doubt anyone else has tried, either.
If there's doubt, there is no doubt: don't do it.
I go with the floor jack idea.
Just my two cents
Old May 31, 2025 | 08:54 AM
xalty's Avatar
shock will hold the spring in without the upper ball joint hooked up. on the 40s and later you have to more mindful of this, if you drop the sub without taking the springs out first you’re asking for trouble
if you’re still scared i’ve popped springs out with just a chain running through it. extended 3/8 electric ratchet and dump the bolts
Old May 31, 2025 | 11:12 AM
Jagboi64's Avatar
I like that phrase, and that is the conclusion I am coming too.
The project is I am converting my Daimler DS420 to ABS brakes. The caliper and disk are the same as the XJ6/12/S. However the upright is similar, but different, and the hub and caliper offset is different. I have the hubs with tone rings from an ABS equipped XJS, but now I'm thinking it might be easier to turn a shoulder on my existing hub to press on the tone ring. Daimler hubs are NLA, so that's why I was thinking of going all XJS.
benji808
Mar 10, 2026 12:32 AM
my420
Feb 17, 2024 09:31 AM
Mr.B
Aug 28, 2015 02:14 AM
scarbro2011
Jan 30, 2014 05:32 PM
grommet
XJ40 ( XJ81 )
Feb 28, 2009 06:45 AM
