Leaking rain water in back seat - help needed
Old Sep 24, 2012 | 02:40 PM
dino's Avatar
Question Leaking rain water in back seat - help needed
Hello everyone - I've searched the forum and can't seem to find an issue like this, so I'm hoping someone might be able to help....
The problem is that rain water is leaking from where the rear speakers are, it's as if water is coming in from behind the speakers. As a result, when it rains heavily under the back seat is full of water.
Hopefully someone has a suggestion or two?
Thanks !
Old Sep 24, 2012 | 07:41 PM
JagZilla's Avatar
Are you sure it's coming from behind the side-mounted speakers? If so, it almost has to be that your fixed side window seals are bad. I've never heard of that happening.
A much more common leak is from the rear window seal. A leak there allows water to run under the carpeted window package shelf, down the rear bulkhead (behind the rear seatback cushion), and pool under the rear seats.
Back in 2001, Ed Sowell had a leak around his rear window seal. It caused massive damage. He documented the damage here:
WindowSeals
In fact, his whole site is extremely helpful to the XJS owner. Check it out here:
Ed's Jaguar
If it isn't already linked somewhere on this site, I would HIGHLY suggest that the admins add this link to the XJS HOW TO quick links on this forum.
Old Sep 25, 2012 | 05:04 PM
dino's Avatar
Many thanks for your reply JagZilla, much appreciated! I have ordered some rear window seals so we'll see if this improves the situation....
I also have a 1988 XJS Convertible, and I'm trying to source some rubber door seals. I cannot get hold of them anywhere, and i've asked around Jag specialista here in the UK.
I don't suppose you (or anyone else!) could recommend somewhere I could order these from?
BrentGardner
29
Dec 16, 2024 12:13 AM
RaceDiagnostics
Dec 11, 2015 10:12 AM
Spikepaga
Aug 30, 2015 12:59 PM
innzane
Aug 27, 2015 07:58 PM
divingmom
Aug 25, 2015 07:54 PM
