Left Rear wheel clunk over bumps and turning
Old May 20, 2019 | 06:29 PM
Spikepaga's Avatar
Default Left Rear wheel clunk over bumps and turning
Hi gents-
I am having, what sounds to me, a clunk from the rear left wheel that I can hear when I go over bumps as well as when I make left turns.
The car was up in the air for an engine oil change and a differential oil change, and I am going to be replacing the perished transmission mount, and some arm bushings (see photo below) that are also perished, but I am still not convinced this is my only issue causing the noise. Anywhere else I should look that would be causing both the clunk over bumps and when turning?
Old May 20, 2019 | 08:53 PM
Spikepaga's Avatar
Well, based of archived posts, it does sound like a bad transmission mount will cause the symptoms and sounds I am having. First step is probably to just replaced that and the perished bushings in the photo above
944xjs
Sep 28, 2019 12:22 AM
Spikepaga
Aug 23, 2018 02:55 PM
Johnken
Jul 29, 2018 10:17 PM
Lawrence
Oct 4, 2014 02:21 PM
p-Rock
Jul 27, 2012 06:00 PM
