Lookie what i found! V12 carb'd intakes.
Old Feb 5, 2012 | 08:27 PM
M90power's Avatar
Default Lookie what i found! V12 carb'd intakes.
Jaguar V12 Dual Quad intake Manifold XJ12, XJS | eBay
This auction is for a set of cast aluminum intake manifolds for converting any year Jaguar V12 (including HE models) to a dual quad normally aspirated setup. This eliminates the problematic fuel injection system and also allows easy access to the cams as well as an overall clean looking motor. The 5.3 Litre V12 is roughly 600 CFM At 6,000 RPM but we have used two 500 CFM four barrel Carbs because they are affordable and work just fine. We have used this setup for marine application, as pictured, and have a full marine conversion available upon inquiry. The Dual Quad setup would work for automotive application and make for a great Hot Rod V12. As for fitting underneath the hood of your Jaguar this would have to be measured, for the XJS we do have a cast aluminum bolt on hood scoop available as pictured above and available upon inquiry.
This auction in only for the Intake Manifolds and the buyer pays the actual shipping costs.
Cheers,
Kelly Berg
360-319-9528
looks like this setup, with a couple of sweet little blondes named holley, would be less than half the cost of the 12 pack Weber setup. and 1/3 of the tuning, lol.
but it seems to me, you might experience an enormous amount of BOG at WOT with 500+CFM carb's. i suppose you would never notice it in a marine setup since in a boat, you normally roll on the throttle slowly.
Old Feb 5, 2012 | 11:58 PM
Sarc's Avatar
The boat looks awesome !
I would imagine it gets kind of hot in the drivers seat though....... judging by how they've routed the exhausts :-)
Old Feb 6, 2012 | 04:48 AM
Sean B's Avatar
are they not heat exchangers?
Old Feb 6, 2012 | 02:06 PM
JameyXJ6's Avatar
interesting, but very very expensive!
Old Feb 6, 2012 | 02:41 PM
warrjon's Avatar
By the time you have installed these with a couple of carbs and cut a hole in the bonnet for it all to stick through you could have replaced ECU and installed distributorless ignition for about the same money.
BTW the exhausts will cool enough to touch as they are water cooled.
Old Feb 6, 2012 | 07:58 PM
calvindoesntknow's Avatar
thoes things fit over the distributor!
Old Feb 9, 2012 | 06:43 PM
ronbros's Avatar
the pic show dizzy in the middle
Old Apr 2, 2012 | 03:31 PM
M90power's Avatar
im halfway to a set of these. cannot FREAKIN wait!
Old Apr 2, 2012 | 03:40 PM
JameyXJ6's Avatar
I thought about those too, but didn't want to cut my hood!
Old Apr 2, 2012 | 03:51 PM
M90power's Avatar
i doubt you have to cut your hood. im banking on being able to make these fit by using a low profile air cleaner, removing the hood insulation, and modifying the motor mounts.
Old Apr 2, 2012 | 03:58 PM
JameyXJ6's Avatar
You really can't lower the motor any further on the mounts, the oilpan is practically touching the rack already. If you check you'll see there isn't much room at all between the engine and the hood, but removing the insulation might help some.
The original V12's in the E's had twin updraft carbs right about where the butterflies are located now.
Old Apr 2, 2012 | 04:08 PM
M90power's Avatar
they had quad updrafts.
Old Apr 2, 2012 | 04:36 PM
warrjon's Avatar
I thought the original E type V12 ran quad side draft Stromberg's
Old Apr 2, 2012 | 04:40 PM
JameyXJ6's Avatar
I thought they were updraft Strombergs...I'm not an expert on the E's though
Old Apr 2, 2012 | 04:44 PM
JameyXJ6's Avatar
JAGUAR E TYPE V12 INTAKE MANIFOLD WITH 4 CARBURETORS STROMBERG | eBay
Old Apr 2, 2012 | 04:50 PM
warrjon's Avatar
Those carbs are sidedraft
Old Apr 2, 2012 | 04:55 PM
JameyXJ6's Avatar
Either way, if you were going to go with carbs, I think you could probably make a manifold to go over the valve covers and find some updraft/sidedraft carbs.
For that matter, you could probably just remove and plug the injectors and use the same intakes.
Old Apr 2, 2012 | 06:39 PM
ronbros's Avatar
YIKES!! this post has gone ballistic down!
carburators, really?? this is 2012 not 1965!
and how you gonna twin-turbo a V12, with carbs, and have a nice running vehicle? cheaply!
Old Apr 2, 2012 | 08:12 PM
M90power's Avatar
i wouldnt mind running an e-type setup. wonder what those setups are going for.
Old Apr 8, 2012 | 07:49 PM
M90power's Avatar
i found a set of E type manifolds for 70 bucks. very tempting. cant find any strombergs to go with it though.......
