looking for small parts
Old Nov 27, 2016 | 08:14 AM
malc4d's Avatar
Default looking for small parts
Does anyone know of a facelift car being parted out near Orlando ?
I'm looking for the white plastic clip (part 6 ) that hold the locking rods inside the door.
Old Nov 27, 2016 | 09:11 AM
JagCad's Avatar
Interesting device !! Seems that it's purpose is to support the actuating
rods mid length.
As t is plastic, odds are that any used ones are failed or about to. the age thing and plastic.
My inclination would be to make a facsimile from carved and drilled alloy or plastic. Or cut and weld metal. A mall flat piece, a screw and two tubes welded or brazed to it. Lube that and it is forever....
The idea seems to reduce flexing of the rods. So, I might think of beefing them up to stand alone???
Carl
Old Nov 27, 2016 | 09:59 AM
JTsmks's Avatar
Contact David Boger at everydayxj.
Old Nov 28, 2016 | 07:07 AM
Vee's Avatar
Vee
BEC9538 Door Lock Clip Workaround
Boom! This is the work around that I used. Never had any trouble with it!
Old Sep 8, 2019 | 02:48 AM
Staatsof's Avatar
I don't see why a good epoxy meant for plastics wouldn't work?
We have one of those small blade type coffee grinders which my wife developed a habit of banging on the counter to loosen up the grounds when done.
After many years of this the base broke in a 360 degree circle off the bottom of the grinder.
I cleaned it very well, scuffed up the area surrounding both sides of the crack and used epoxy to glue it all back together with a nice build up everywhere.It's been working just fine for 3 years now.
I also just finished using an epoxy based repair for cement to anchor some stair rail posts and re-attach two broken corners of some cement stair treads. If you get the right product it should be great.
Glue some quality pieces of plastic on there and drill it to fit.
Old Sep 17, 2020 | 04:59 PM
rsdmitch7's Avatar
Contact Jim Staub, Arizona 480-203-8091. Excellent fair man to do business with.
Mitch
Danbury, Ct
Old Sep 22, 2020 | 06:29 PM
equiprx's Avatar
I probably have a few in my parts bins left over from my 94s.
Give me a call or text to 650-455-1110.
Steve
Old Sep 23, 2020 | 05:03 AM
BradsCat's Avatar
I have the part off an '88 I am parting right now. Looks exactly like your diagram. PM me and its yours.
Old Sep 23, 2020 | 08:33 AM
malc4d's Avatar
Hi guys, the original post was in 2016 and I found a way around it. Just cant remember now how.... maybe a part from Autozone or similar.
K, just read my reply in 2016 and yup I got parts from autzone.
But could still use a couple of good ones for the off chance I ever have to take the door apart again.
