Lucas male/female connectors?
Old Sep 3, 2017 | 08:55 AM
Daim's Avatar
Default Lucas male/female connectors?
Hey guys,
I am doing my cruise control and replacing all the wires and co and need some connectors for the plugs.
Problem is, they are the "male" and "female" style crimp on connectors. I have no idea where to get them from and what they are properly called. All I know is that the standard look-a-like connectors I can get here do NOT fit... You can force them to fit but they don't properly fit...
Anyone got some ideas?
Damien
Old Sep 3, 2017 | 09:38 AM
Doug's Avatar
Mwybe some browsing here will reveal what you're after? They seem to have stuff unique to British cars
https://www.britishwiring.com/
Old Sep 3, 2017 | 10:48 AM
Greg in France's Avatar
Amazon Amazon
If you mean this type, Daim, they are standard "Lucar" connectors and have 1/4 inch blades (6.3mm). Amazon sell them as kits or in 50 packs of each type
Amazon Amazon
Greg
Old Sep 3, 2017 | 11:30 AM
Daim's Avatar
Unfortunately not Greg. No spade connectora. If you unplug your fuel injector harness or cruise bellows, you'll see the ones I mean.
Old Sep 3, 2017 | 12:22 PM
My FI harness plugs are not crimp terminals, as far as I can see, they are some sort of proprietary rubber solid items.
Greg
Old Sep 3, 2017 | 12:26 PM
Daim's Avatar
Greg
If you remove them from the plug, they are crimp connectors
Old Sep 3, 2017 | 01:47 PM
Jagsandmgs's Avatar
I think you're mixing up Lucas bullet connectors with US style trailer connector pins. They are a different size The cruise control connectors are standard US style three wire trailer wiring connectors. Look for Hoppy brand, they fit fine. i've never found a fuel injector connection block that looked exactly the same, but found four two wire US style trailer wiring connectors turned on edge are a perfect fit.
Old Sep 3, 2017 | 02:07 PM
Daim's Avatar
Awesome tip mate!
http://picocanada.com/en/view_product/1872
Exactly what I was looking for!
Old Sep 5, 2017 | 06:48 AM
JigJag's Avatar
Thanks for that link Doug!
Dang! They don't appear to have to amplifier plug.
Old Dec 8, 2017 | 11:31 AM
Daim's Avatar
Well, I'll quickly undust this...
After looking at a way to get some of those US trailer plugs and wires, it was in the end cheaper to buy the CC harness section from the fire wall to the CC plug. Why? 'Coz the same and even the correct colour. So I'll cut one up to use for the CC actuator unit
