Magnetic plug removal
Old Aug 13, 2013 | 01:29 AM
Dr. V12's Avatar
Default Magnetic plug removal
I guess I'm one of the lucky ones that has a magnetic drain plug in the rear diff. What size is it and what do I use to remove it? I tried one of those Gator Grip universal sockets on the end of a 1/2" breaker bar, but all I got was some small pieces from the corners that fell to the floor. Is all hope lost, or can it still be taken out?
Old Aug 13, 2013 | 06:54 AM
AllanG's Avatar
Assuming you have the Salisbury diff, I believe it is a 3/4" BSP plug. Don't know what a Gator Grip is but the right tool is a pipe plug socket.
Cheers,
Allan
Old Aug 13, 2013 | 07:04 AM
Doug's Avatar
You have a square-head drain plug, right? I use the female end of a short 1/2" drive extension to engage the square-head and then and open-end or adjustable/crescent wrench on the other end. If the corners of the plug are not too badly rounded you could probably do the same.
Old Aug 13, 2013 | 11:04 AM
Terry's Avatar
This is probably a good time for a reminder to always make sure you can get the fill plug out of differentials, transfer cases, transmissions etc. BEFORE you remove the drain plug.
I know its not quite the case here, but, it doesn't hurt to keep in mind for other situations. You're kind of up the proverbial creek if you've already drained your fluid and can't get the fill plug out.
Old Aug 13, 2013 | 04:46 PM
Steve M's Avatar
I've never heard of a Gator Grip either; is it related to the Croco Clamp?
Old Aug 13, 2013 | 06:33 PM
JTsmks's Avatar
A "Gator Grip" is right up there with "Vice Grips" in my book....good for rounding stuff off!
Old Aug 13, 2013 | 07:25 PM
matts89xj's Avatar
Most are typically a half inch drive female. If not, pb blast the hell out of it and use an adjustable wrench.
aholbro1
Dec 29, 2024 06:46 PM
Jandreu
Jun 30, 2022 03:10 PM
cissdm
May 3, 2016 06:02 AM
mrplow58
Sep 9, 2015 11:27 AM
kstevusa
Sep 7, 2015 01:12 PM
