Marelli Ignition Modules
Old Sep 28, 2014 | 05:13 AM
Daim's Avatar
Default Marelli Ignition Modules
Hi there!
Whilst sorting my V12 out, I decided it would be best to redo the entire ignition system including distributor cap, ht-leads, plugs and co. At the same time, the iginition modules (located on the front cross member) should be done...
Jaguar seems to say "not available" anymore... But there seem to be enough pattern parts. Has anyone had any experience with them?
Like from Carquest the article 55-1635, or LX-1016 from Standard Motor Products (STANDARD MOTOR PRODUCTS Part # LX1016) ???
I don't fancy buying something expensive and finding out, that my 1989.5 Marelli V12 doesn't like the idea... I'm also not that keen on using used parts, as you don't know how long the part will live on.
Any ideas, tips, and co?
Damien
Old Sep 28, 2014 | 07:02 AM
bigpigpants's Avatar
Cool
Originally Posted by Daim
Hi there!
Damien
I think the item you want is listed on Electronics, Cars, Fashion, Collectibles, Coupons and More | eBay as item number: 400516121491 though the price seems to have gone up since I bought 2 of them at about £26 or so each. I think they are Italian made Cambiare products.
Rgds
A.
Old Sep 28, 2014 | 08:18 AM
mikebaker3's Avatar
I have not had trouble with the transistor modules on top of the radiator or with the coils. I have replaced them at different times and great cost only to find out that the culprit always seems to be the magnetic pickup at the bottom of the timing cover that reads the three fingers on the harmonic balancer to read crankshaft position.
I was only getting about a year and a half life from the sensor. There is an updated p/n and most suppliers such as XKs and Welsh send the updated part. I keep a spare in the car and an 8mm wrench to change it out and keep a wire coat hangar to snake the cable up the front of the timing cover. Jag secures the cable with clips along the left side timing cover bolts. I don't secure the cable. The connector is at the left side of the air conditioning compressor.
I would be driving along and the car would shut off. At first I thought heat was attacking the transistors on top of the radiator. What a great place to mount a heat sensitive component, right on top of a hot radiator. Heat and water were getting to the sensor instead. After about 45 minutes it would start right up after the sensor cooled.
Another weak spot is moisture getting into the connector at the compressor. Disconnect, clean with contact cleaner and apply bulb grease and you will not have trouble with that connector.
Be careful about distributor caps. You want one that says marelli on the cap. aftermarket caps without marelli embossed have had trouble with the carbon spring loaded center contact inside.
If you change the rotor (which is actually two six cylinder rotors stacked on top of each other) apply some RTV silicone to the inside where the rotor fits onto the top of the distributor shaft. The rotor slowly burns through the plastic and shorts one back of cylinders which then continue to expel gas into the Cats and fry them. On my car, that was on the r/h side while the left side operated normally.
Old Sep 28, 2014 | 11:18 AM
Doug's Avatar
Do you have a source? I'm sure many would love to know!
Last time I looked (3 years ago?) I couldn't find any bona-fide Marelli-made caps. The consensus was that Marelli stopped producing them.
It also appears ( I haven't researched in depth) that Jaguar and 'the usual suppliers' are all selling the very same Italian made aftermarket replacement cap. It might be in a box labeled Jaguar, Airtex, Beck Arnley, Standard Motor Products....whatever....but they're all selling the same thing.
Old Sep 29, 2014 | 09:01 PM
mikebaker3's Avatar
The last Cap & Rotor I bought was from XKs Unlimited.
I have been able to get sensor through XKs and also Welsh Enterprises
Old Sep 29, 2014 | 11:14 PM
Doug's Avatar
Was it true 'Marelli' and, if so, how recently was this?
Old Sep 30, 2014 | 05:35 AM
Daim's Avatar
My cap states Marelli and production date of IIRC 2012...
But please back to the cross member modules...
Old Sep 30, 2014 | 07:22 AM
Greg in France's Avatar
Daim
In my opinion the Intermotor brand modules you showed will be fine. They are probably made in the same facility in Italy as the originals. I have never had any problem with Intermotor parts I have used.
I say buy them and keep the old ones in a little box in the boot.
Greg
Old Sep 30, 2014 | 02:20 PM
Japthug's Avatar
I know a lot cheaper substitute, which is Intermotor 15030.
It doesn't come with the aluminum plate but of course can be exchanged.
I think it is for Lancia or Ferrari Testarossa or something.
I use them for years without any problems on my XJS.
Old Sep 30, 2014 | 03:39 PM
Daim's Avatar
Cheers guys! Something like that is what I was hoping for! Now to order two! And two new coils... Then nothing should let the engine run rough.
Old Sep 30, 2014 | 07:14 PM
mikebaker3's Avatar
The cap has the Marelli logo on it, the rotor was in an Intermodul box. I bought them about a year ago.
hoodun
Nov 20, 2022 02:35 PM
goges
Oct 5, 2015 04:53 PM
leep123
Sep 30, 2015 03:41 PM
zdrapec
Sep 25, 2015 05:49 AM
