Melted distributor rotor and cracked dist. cap
Old Sep 2, 2013 | 01:07 PM
davisalln's Avatar
Default Melted distributor rotor and cracked dist. cap
Left charger on car with the key on for a couple of days. Big mistake. Found that the rotor, dust cover and cap were toast. Replace those items and still wont fire up. Any ideas. The electronic pick up wasnt melted but could be bad. Any ideas out there?
Old Sep 2, 2013 | 03:44 PM
warrjon's Avatar
Need a little more info what model XJS V12 I6 ignition type, There are many different models Opus, HEI and Marelli for the V12 I don't know about the I6.
Old Sep 2, 2013 | 04:28 PM
davisalln's Avatar
thanks for the reply. 87 V12 HEI with lucus distributor. Also, could the voltage booster be the culprit. Can it be tested as well as the pick up module in the distributor? Really appreciate the help.
Old Sep 2, 2013 | 04:29 PM
davisalln's Avatar
the two coils checked out good.
Old Sep 2, 2013 | 05:06 PM
JTsmks's Avatar
The ignition amp GM module is probably shot. Just a guess.
Old Sep 3, 2013 | 05:21 AM
warrjon's Avatar
You will need to check for melted wiring in the HT system and HEI module, if the rotor has melted there was significant current flowing in the system. It is also possible to fry the ECU if you leave the battery connected and then add the charger, depending on the type of charger. I always leave my XJS on trickle charge but remove the battery neg terminal before I connect the charger.
Can you measure the voltage (on the low voltage side of the coil)
a - across the coil + and - terminals
b - from the + terminal to earth
c - from - terminal to earth
and post back
Old Sep 3, 2013 | 06:37 AM
davisalln's Avatar
thanks warrgon. Sorry but not sure what the HT system refers to. Explain? Will measure the voltages on coil and get back later today. thanks
Old Sep 3, 2013 | 06:52 AM
Doug's Avatar
"HT" = High Tension = the high voltage side of the ignition. Coil output, distributor cap and rotor, plug wires.....
Sometimes referred to as the "secondary" side of the the ignition system, with the "primary" side being your low voltage stuff: wiring to the coil, breaker points (remember those?), ignition modules, etc.
Old Sep 3, 2013 | 08:22 AM
davisalln's Avatar
High Tension, DUH, Should have known that. Got into the habit of calling it High Voltage side. Thanks.
Old Sep 8, 2013 | 01:11 PM
davisalln's Avatar
Warren, finally got the voltage measurements you asked for. With the key on and a hot new battery the readings are:
on the coil, positive post to the negative post = 0
positive post to ground = 12 volts
negative post to ground = 0
Hope this helps. Thanks a bunch.
Old Sep 8, 2013 | 03:37 PM
warrjon's Avatar
This sounds like your ignition module maybe suspect. Can you connect the meter between Coil Negative and the positive battery terminal, the meter should read 0 Volts, crank the engine and the voltage should rise to about 2-3Volts.
If this is ok disconnect the wire at the coil Negative turn the ignition on and measure the voltage between the coil negative post and ground, you should have 12volts.
Old Sep 8, 2013 | 04:05 PM
davisalln's Avatar
Ok. sounds like we are on to something. Since the battery is in the trunk, I will need to add a extension to the volt meter lead but will figure out something. Will let you know. Triple thanks Warren.
Old Sep 8, 2013 | 09:54 PM
warrjon's Avatar
Use a set of jumper leads or a big thick cable.
Old Sep 21, 2013 | 04:47 PM
davisalln's Avatar
Warren, cked the voltage from the neg on the coil to the pos. on the battery and got .03 volts ( probably 0 ). When cranking the engine the reading read about .5 volts. Hopes this help. Again, thanks.
Old Sep 21, 2013 | 05:23 PM
warrjon's Avatar
This sounds like the ignition module is faulty. I don't have any experience with these but I do know it's a GM HEI unit.
Can someone suggest which GM unit will replace it...
X308XJR
May 20, 2019 06:50 PM
vwbusbits
Oct 13, 2015 03:43 AM
hoodun
Sep 28, 2015 01:08 AM
