misfire cylinder 3 1994 xjs 4.0 6 cylinder
Hi,I have a misfire on cylinder 3 on 4.0 6 cylinder 1994 xjs.I have swapped coil packs,changed plugs and swapped injectors-it always shows an obd code for misfire on cylinder 3 and does notchange with swaps.Anybody had a similar problem?
I'd look at the injector next. Perhaps remove all six and get them cleaned/refurbished? At the very least bench test the injector with a 9v and a momentary switch. You'll burn out that injector quickly...
boliversmith
Jun 2, 2011 08:34 PM
