Need help with finding / identifying a part
Old Jun 1, 2016 | 02:51 PM
XKR8's Avatar
Default Need help with finding / identifying a part
Hi Guys
Please see photo attached , the part which is marked with a circle , can anyone tell me whats the name of this part?
THANK YOU
Attached Thumbnails Need help with finding / identifying a part-ee03024c-d889-4ac3-9d9c-00d377f464f9.jpe
Old Jun 1, 2016 | 03:05 PM
XKR8's Avatar
its for 1995 XJS Conv. 6 cylinder engine
Old Jun 1, 2016 | 03:20 PM
Mac Allan's Avatar
It's called "Exhaust Downpipe and Catalyst" see link below:
Exhaust Downpipe/Catalyst-4.0 Litre-Canada/Usa - Parts For XJS from (V)179737 to (V)226645 | Jaguar Classic Parts UK
Old Jun 2, 2016 | 06:54 AM
XKR8's Avatar
thank you very much
where can i find this part ?
thanks again
Old Jun 3, 2016 | 10:20 AM
RickE's Avatar
I just purchased an aftermarket direct fit downpipe and converter manufactured by Eastern Catalytic Converter. You can go to their website to determine the one you need (straight pipe or flared) and then check prices with several online vendors. I also purchased new O2 sensors. Two things - the price of the O2 sensors were double what I paid at some of the vendors and the donut gaskets that came with the converters ended up leaking. I had to pull the converters back off and putting larger donuts in. I would say where I made my purchase but not sure if allowed on this forum.
One more thing is to make sure the O2 sensors are connected exactly the way they were on the original.
Old Jun 3, 2016 | 03:01 PM
XKR8's Avatar
thanks Rick
Old Jun 9, 2016 | 10:37 AM
XKR8's Avatar
Which kind of gaskets do I need and where can I find them?
THANKS
Old Jun 9, 2016 | 11:51 AM
Vee's Avatar
Vee
You'll need two EBC9388a and a CAC4336 from what I can see on the JDHT website. You can use Google to find them. They're available from a lot of places, including eBay and RockAuto, as well as the typical Jaguar specialty shops. You could even get the dealer to get them for you. You may need the special, one time use only locking nuts JZN100024.
You might want to consider replacing your exhaust manifold gaskets as well, since you're already there? I believe you're supposed to loosen the manifolds to join up the pipes. If that's the case, you may as well change out NBC2909AA and EBC11330. And check out NBC2903AC.
Lastly the studs connecting that downpipe to the manifolds didn't always come off... I might recommend four EAC3823 parts.
Might be best to put together an order through JDHT. Everything should still be available. (Buy work gloves and make sure you have a torque wrench and long socket extensions (24" min) to do this work. You'll be spending quite a bit of time under that car to loosen/tighten those JZN nuts I referenced. Fair warning, you get one shot with those...might want to order a few spares.
Old Jun 9, 2016 | 02:19 PM
XKR8's Avatar
THANK YOU
Old Jun 9, 2016 | 03:27 PM
Vee's Avatar
Vee
No problem. I replaced the exhaust manifolds, so I've already done most of the work you're about to do. I think loosening the manifolds makes it easier to make the connection to the downpipe and is recommended anyways.
I hope you have a service manual. I remember it having a pretty good writeup on what to do.
Make sure you have antiseize.
aquifer
Jun 3, 2016 09:08 PM
haljohnsonjf
Jun 1, 2016 12:40 PM
nicobenny
Jun 1, 2016 11:24 AM
1 of 19
May 27, 2016 09:20 PM
Safari
May 26, 2016 10:33 PM
