new wheels?
Old Jun 5, 2013 | 03:50 AM
fritzvis's Avatar
Default new wheels?
I've been looking for a nice set of 17" wheels (2nd hand) for my XJS. But there do not seem to be much around.
Can anyone tell me what to look for? size?
I've heard people talking about adapting BMW wheels that fit XJS? Since there are a lot more of second hand BMW wheels, that would be a good option?
Can anyone give me more info about that matter?
Would the wheels of a BMW E39 fit? (that's the older 5 series BMW)
best regards,
Fred
Old Jun 5, 2013 | 04:24 AM
warrjon's Avatar
best regards,
Fred
The fronts will fit - offset on the 17x8 M's are 19mm bore is correct and you will need wobbly nuts to account for the different PCD. The rears might the 17x9 rear wheels have a 25mm offset if my memory serves me correctly this might have the tyres rubbing on the inner guards.
Old Jun 5, 2013 | 05:02 AM
fritzvis's Avatar
So they can be machined to fit?
these would be my choice, I think they match the XJS perfectly (like Mish's car)
Old Jun 5, 2013 | 05:31 AM
warrjon's Avatar
You would need to talk to a wheel shop about machining the rear to increase the offset. It can weaken the wheel if the hub becomes to thin.
Old Jun 5, 2013 | 05:36 AM
fritzvis's Avatar
These are for sale and seem to be Original Jaguar wheels but I'm not sure what model...
17" with tires for $350...
would these fit an XJS?
Old Jun 5, 2013 | 11:11 AM
Hep320's Avatar
Default XK8 wheels
17" inch XK8 wheels, fit perfect no mods required and they are inexpensive.
Old Jun 5, 2013 | 11:41 AM
86jag's Avatar
Those are from an S-type jaguar and won't fit. Jag has two different wheel bolt arrangement. You need to look at wheels from an xk8 till 2006 or an xj till 2003 for 17" wheels. The x-type, s-type, xj 2004- and xk 2007- all have the newer metric bolt spacing, these wont fit your car.
Old Jun 6, 2013 | 01:54 AM
calvindoesntknow's Avatar
look for a set with the 3 series bmw offset. 30-33mm and have the hub centers bored out to 74.1
Old Jun 6, 2013 | 05:04 AM
warrjon's Avatar
Jag has 3 different PCD (bolt patterns) 5x108 (S and X Type), 5x120 ( Later XJ/XF/XK) and 5x120.65 (pre 2004 XJ/XK), not to mention hub diameter ans offset. The XJS is pretty unique in its offset the front needs a low offset and the rear needs a higher.
If you use BMW they are 5x120 you will need wobbly nuts to account for the slight difference in PCD. DO NOT bolt 5x120 directly to your XJS it uses 5x120.65 there is a chance you will snap wheel studs.
Old Jun 6, 2013 | 11:40 AM
FastKat's Avatar
I second this, however, if it was up to me, I would avoid the "wobbly nuts" on such a critical application. I would try to recut the bolt seats to the correct pattern by either 1) making a jig, or 2) having a machine shop do it on a mill.
If you insist on using the wobbly nuts, I would at least by certain that you have the proper wheel-to-hub fit, so the hub is sharing the load with the studs.
I don't think the BMW wheels have the optimal offset for our cars anyway (30-33mm) so I abandoned the BMW wheel idea altogether. Too bad though - they have some really nice wheels... especially the "Style 5" 2-piece BBS wheels!
H20boy
Dec 24, 2024 03:23 PM
PMKimpton
Aug 3, 2019 08:22 PM
scooternva
19
Oct 27, 2015 02:14 PM
DustysSon
Sep 13, 2015 04:17 AM
lickahotskillet
Sep 11, 2015 07:54 PM
