newbie: how to test fuel pressure?
Old Dec 2, 2012 | 12:50 PM
tedhaywardart's Avatar
Default newbie: how to test fuel pressure?
Hi all! Typical newbie question: Where is the ideal place to tee-in a fuel pressure gauge to test my 85 v12 ? Although both my regulators are still intact, I understand only one is needed. Ideally, I would like, in the future, to install a permanment pressure gauge under the hood. Thanks in advnce!
Ted in BC, Canada.
Old Dec 2, 2012 | 01:16 PM
Doug's Avatar
On the left side of the fuel rail there's a pipe/hose line that runs from the LH regulator to the fuel rail. "Tee" into the rubber section of that line for your fuel pressure reading.
The hose will have to be replaced afterwards but that's easy....just cut off the old hose and press a new one on over the barbed nipples. Make sure to use fuel injection grade hose.
It's the right side pressure regulator....the "inlet" regulator....that can be removed.
toronadomike
Jan 22, 2026 10:13 PM
silkcat
Jan 18, 2025 04:29 AM
dsnyder586
Dec 29, 2024 07:39 PM
Bcrary3
Feb 21, 2023 04:29 AM
ccfulton
Sep 20, 2015 05:15 PM
