No crank 1986 XJS V12
Old Jul 3, 2023 | 08:21 PM
XJS12's Avatar
Originally Posted by Grant Francis
Return .line blocked would give excessive pressure and cause lots of running issues., normally. In your case I reckon "flooding" and that is stopping running, I think???
Trace that hose to the spigot at the firewall, remove that hose and put the end in a jar. Switch ON the Ign to prime the rail and ensure you have flow that far down the line. If so, read on, if NO then the issue is possibly in the fuel cooler (I remove the fuel lones from them on ALL my V12's and 6cyl)
If tht test proves OK, then its time to get "down and dirty" with the beast, and follow the steel line towards the rear of the car. LOOK CAREFULLY around the jacking points, as tyre fitters are reknown for jacking cars wherever the pads hit, and crushing that line, I have had a number like that.
There is a hose in that line where it travels OVER the rear cradle, usually leaks fuel, but it may have collapsed internally and plugged itself. PITA to do with the cradle in the car, but doable all the same. You will need that warped sense of humour, and that whole new language you are learning quickly, haha.
In the boot, front corner, LH side, obviously, is the end of that pipe/hose, and it twists around to enter the tank in that corner. Usually no issues with that hose, as the Spare Wheel protects it very well.
Take your time, one section at a time.
GREAT NEWS!! The car started today and it sounded really good given it’s been sitting for some time now. Identified the plug in the fuel system that’s now cleared but there is a pretty severe leak. it’s narrowed down to a spot when I can find it pretty easily (I hope). Will be looked at soon. I ran the car off an external fuel tank and pump and it ran good until the gas ran out.
Next steps would be to find and fix the leak and get a new fuel pump. But as for now, the no crank/start issue has been resolved.
Appreciate the help everyone!
lambo911
Jan 25, 2023 05:38 AM
Parker 7
XJ40 ( XJ81 )
88
Dec 13, 2022 11:02 AM
vignerons33
Aug 18, 2022 07:57 AM
XJS87
May 15, 2019 03:05 AM
RandallCB
Mar 25, 2009 06:37 PM
